3dr ecu???
Leve l 1 ecu will be in your car mate , Level 8 is the ecu most people up grade to , change the tps sensor to a 4x4 one and change the connecting wires round thats it, im sure
Got a level one on my 3 door jusnt now , no reason to change so its staying until i need to upgrade for what ever reason
level 1 ecu as standard, a level 6 ecu from a 2wd sapphire is straight swap and a level 8 from a 4wd is also easy as you only need to change the tps and swap the wires around, level 6 is better than L1 so I was told.
my car is stage3 low comp 500 cooler ect but is getting rebuild at the mo bd10s new pistons ect so was just thinking or changing the ecu but dony want the hassle of changin wires ect so l6 is a beeter ecu for me 2 use
ECU types used in Sierra (RS) Cosworth:
All type of Sierra (RS) Cosworth use a Weber Marelli type of ECU (Engine Control Unit or motormanagement) however, these ECU's have changed over the years as demands grew and computer technology improved.
Although, as far as known, all ECU's use the same connector pin-out (und thus can be electrically interchanged) one can not use for instance the latest ECU on the earliest Cosworth. This is because the ECU is fully "tuned" to the engine characteristics which have dramatically changed over the years. The latest ECU's also use input from several additional sensors which are not available in older models.
Here is an overview of ECU's used and how to recognise them:
Level 1:
Used on the RWD hatchback RS Cosworth, has 64Kb of memory. Can be recognised by the mounting flange on the front face and a yellow CO adjustment screw.
Level 6:
Used on the RWD sedan (RS) Cosworth, has the same capabilities as the level 1 model but uses totally different electronics. That's why Level 1 and Level 6 chips can not be interchanged.
Can be recognised by the mounting flange on the front face (like the Level 1) and a white CO adjustment screw (Level 1 has a yellow one).
Level 8:
Used on the 4x4 sedan (RS) Cosworth, has twice the memory storage capacity (128Kb instead of 64Kb) as Level 1 and Level 6. That's why chips can not be interchanged.
Level 8 was available in 2 type since the engine in the 4x4 was available with and without hego-sensor (i.e. with and without catalytic convertor).
Can be recognised by not having mounting flanges and a green or red label with WD48.08.
The one with the green label and second code IAW048/01 is for the catalytic convertor (US83) model.
The one with the red label and second code IAW048/02 is for the non catalytic convertor (15/04) model.
It is uncertain if units/chips can be interchanged between red and green types/engines.
There are also Weber Marelli P8 (no flanges, white label IAW48/P8) and Ford EECIV (totally different from Weber Marelli, central bolt to hold connector) ECU's around. These are however only intended for use on a Escort RS Cosworth but you might find them in some motorsport Sierra's (RS) Co
Level 1:
Level 6:
Level 8:
if memory serves me right ,yes.
If i could be arsed i could go in the garage and have a look but the dogs will jump all over me and i cant be bothered
DixieTheKid
14-09-2015 09:04 PM
