Recirc D/V help (pic)
Old 21-02-2007, 08:43 PM
gwynny
gwynny's Avatar
Default Recirc D/V help (pic)
Should there be a hose attached to my recirc d/v as its blowing a bit of shite out onto my hoses...
Or should I ditch the d/v????
Old 21-02-2007, 08:50 PM
Tony Rs
Ebony black Sapph Cos
Tony Rs's Avatar
when i brought my cos it had the same thing , the pipe that comes out the turbo should have another outlet to go onto the dv , just take it off and put a normal one on or just completly remove it mate
Old 22-02-2007, 07:55 AM
foreigneRS
Testing the future
foreigneRS's Avatar
the clue is in the question - recirculating means that the output from the d/v should go back into the inlet of the engine. as said above, the hose between filter and compressor inlet should have a fitting for it.
personally, i would remove it completely (but make sure that you block all holes). tip - a piece of broom handle fits perfectly
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
07-10-2015 12:56 PM
griffo69
04-10-2015 11:58 AM
locum8
01-10-2015 01:50 PM
Quick Reply: Recirc D/V help (pic)
