Cometic head gaskets!!
Just got a cometic multilayer head gasket 1.3 thk and was just wondering if the head needs tightening more than standard settings???
Any one had any probs with these gaskets???
P.s for a 2wd saph!!!
Originally Posted by nik t
standard settings mate, 90foot pounds in stages.
welseal around the gasket,stops oil leaking which can sometimes happen
on multi shim gaskets.
Whats this welseal stuff n where do u get it???
According to the manual :
1. use a little oil on the underside of the bolt heads and a bit on the threads
2. torque to 45-50 Nm
3. tighten a further 180 degrees
4. check that when a torque of 110Nm is applied that none of the bolts move
There are variations of the "correct" method above, but the most important thing with fitting a cometic gasket is that the head needs to be flat (ie skimmed), as does the block (which isn't good enough if it hasn't been decked).
If it is the newer COMETIC it will have sealing edges around the oil holes as standard anyway, and they do seal properly the new ones, the old ones did let oil out very often.
The SINGLE PIECE METAL ONE IS ACE, from VICTOR REINZ, ie oe kit maker to LAMBO, FERRARI< ASTON MARTIN etc etc.
Yes should be the new one from them as they have a high turnover and old ones are probably long sold by now.
ps COMETIC ALLOY FOAM gaskets very very good and anti creep and reusble too, for inlet side of things.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
