is a 4x4 cosworth diff offset?
just been measuring my chassis on the rs200 replica and it seems the rear diff is 20mm offset towards the passenger side.
is this correct,is it offset from standard?
cheers
dave
cheers
dave
if you mean the input flange that the prop bolts to, this should be central
if you mean the rear cover - then this will be offset due to the crown wheel being offset where it engauges on the centrally mounted pinion, making the drive shafts different lengths
