lil help please :)
lil help please :)
hi guys, what is required to run a 2wd engine on a l8 ecu?
obviously a l8 ecu, but does any sensors require to be changed or modded? thanx in advance
Im running an l8 on my 2wd and was told i had to change to a 4wd tps and change the outer wires top to bottom,because the 2wd tps has a different resistance,that was from msd.It runs mint
Football Cwazy
Originally Posted by tabetha
You can EITHER CHANGE THE TPS or just swap outer two wires around, whichever is easier for you.
L6 = PF01
L8 = PF09
then if you have a 2wd loom you must switch the outer two wires going to the PF09,
if you have fitted a 4wd loom to a 2wd car with L8 and PF09 then obviously no wires need changing.
again if you fit a 4wd loom to a 2wd car with L6 and PF01,then you have to switch them round.
andre_k
23
04-05-2005 11:18 AM
rs_daz
14-11-2004 05:02 PM
