cossie revs sticking
Old 05-02-2007, 08:43 PM
cossiechuckie
cossiechuckie's Avatar
Default cossie revs sticking
my 4x4 cossie has suddenly started sticking the revs at 3000rpm. if you drive under 3000rpm its fine but as soon as you go over that and changegear the revs stay on. any ideas, cheers
Old 05-02-2007, 08:53 PM
AndyCanning
AndyCanning's Avatar
had these when i went to turn my dads over this time round. the throttle body kept sticking... what colour is yours mate... i might have seen it around leyth
Old 05-02-2007, 11:06 PM
Reece
Reece's Avatar
ye mine does this. theres a cilinder censer on the plenem idel positionin valve or summet just unplug it
Old 06-02-2007, 03:06 PM
First determine if it is the cable sticking, maybe due to being melted on turbo, from what you say does not sound like the usuall ISCV problem, but worth a look ?
Old 06-02-2007, 04:54 PM
kingdragon
kingdragon's Avatar
hmm... I had the same problem twice.
Both times was found in the same place. I'll try to explain it to you. There is a valve for keeping the idle steady in the morning when you first start the engine. After a while it drops down the revs when it gets warm.
By 99% is this valve. As for the position I am not sure where it is as my engine is an 1.6 CVH and the place is behind the CFI unit.
Hope it helped you mate.
Old 06-02-2007, 08:29 PM
cossiechuckie
andycanning, its flint grey mate. think its the idle control valve thats takin the piss.
Old 06-02-2007, 09:48 PM
Csm
Csm's Avatar
iscv off car and soak it in carb cleaner ,u will probs see the shite run over ur fingers as u spray it
Old 07-02-2007, 10:09 AM
AndyCanning
i will look out for you mate
when i am using the saph i will give you a shout.. piccys or summat
Old 07-02-2007, 12:26 PM
cozmeister
More boost Igor!
cozmeister's Avatar
Default Re: cossie revs sticking
So you mean that it's idling at 3k? and when you let off to change gear, the revs go up/down to 3k?
Inlet manifold gasket or other air leak...?
Old 07-02-2007, 05:35 PM
cossiechuckie
no mate, when you rev it from idle to 3000rpm the revs stck, but under that its fine. Andycanning whats the saff ure usin cos il look for you
Old 07-02-2007, 06:03 PM
cozmeister
More boost Igor!
cozmeister's Avatar
Does it do that when you push the throttle linkage, with the pedal, or both? And does the throttle linkage seem to stick or feel stiff when you push it with your hand?
Old 08-02-2007, 11:30 AM
AndyCanning
i should be using my dads its 4x4 and standard mate, i use my focus st170 02 reg in blue 5 door
Old 09-02-2007, 08:58 PM
cossiechuckie
not seen u bout mate mate, but get tunnel visionmost days, il keep an eye out for you, cant miss my car just look for the dirtiest saff u can see around and thats mine
Old 09-02-2007, 09:45 PM
AndyCanning
if you ever go past cannings then you will see my car mate...
Old 10-02-2007, 02:12 PM
cossiechuckie
is that still at side of bus station
Old 10-02-2007, 04:19 PM
AndyCanning
no mate, thats the old one...
across the road from spinning gate car park
sorry for the off topic conversation
Old 10-02-2007, 09:27 PM
cossiechuckie
ah near iceland cos im only 2 mins from there mate
boeb
09-01-2020 05:11 AM
07-10-2015 12:56 PM
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: cossie revs sticking
