3 pipe breather system parts
just took my inlet/exhaust manifolds of the cosworth 4x4 lump in the rs200,plannig on doing the 3 breathers
is this right,wan`t to get all the bits ready to do it.
pipe where the kidney box was,this the the adaptor for the job ain`t it?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...me=STRK%3AMEWA %3AVRI&viewitem=&item=220077716930&rd=1&rd=1
remove bung under turbo (3/8 npt?) and fit adaptor
where can i get 1 from?
cam cover modifyied to accept adaptor,i have seen a picture of where it is fitted,passenger side rear (there is a casting on the underside to drill out)
as above where from?
is it best to fit push on pipe or use aeroquip pipe and jic fittings? with the block and cam cover adaptors modifyied to accept jic fittings.
the breather tank should have 3 inlets and 1 outlet to the sump (near where the kidney box was fitted)
is that it?
thanks for time,loads of questions there
cheers
dave
is that it?
cheers
dave
i know on the bailey breather is as follows
pipe from kidney box to breather tank
pipe from cam cover to breather tank
pipe from adaptor under turbo to breather
vent pipe large bore from bottom of breather tank to atmosphere under car
you can get the fitting kits they are about 45 quid with postage
been looking at the bailey fitting kit,i don`t want normal plastic pipe.
i love the look of aeroquip hose in engine bays
can you just buy the adaptors seperate?
dave
dave
the adaptor on the rocker is just a piece of straight pipe
you can make the one for the block with a male iron end feed fitting from a plumbers merchants
155lee
06-09-2016 11:10 AM
