ignition live
If you are putin the gauges in the center vents it might be easyer to use the headunit swichable ,if its still got the standerd wires then the yellow one is constant live and the red one is ignition live
Is it just to backlight the gauges? If so take a switched live off your light stalk.
And, if you don't have one i'd invest in a multi-meter. You can pick up a new one for as little as £3. Then there is no guessing......
