How to get Chattering on a 4wd cossie????
My mate has a 4wd cossie. Totally standard bar a NMS Gunship chip and an aftermarket exhaust.
Is it possible to make it chatter or flutter?
I know that this is not caused by the wastegate but the air rushing back on to the turbo blades when the turbo stalls.
It still runs the standard airbox.
Any ideas?
Many thanks.
Any ideas?
Many thanks.
blank off standard dump valve and u should get chatter whether u have airbox or con. mine does it everytime i even slighty coe off throttle.
Cossiemodo
My chattering scares pedestrians hundreds of meters away, running RS500 I/C and a metal mesh cone filter, and the old broom handle where the dump valve was, it's LOUD.
Yep, blank dump valve and blank off vac pipe
Got a massive foam filter on mine, stage 1 and it chatters and the dump valve is great as well.
For some reason I thought you got one or the other - either chatter or dump valve so was really suprised when picked up my new motor and had both. I loved it!
Russ Payne
25-09-2015 08:29 PM
