Gauges
Gauges
my new gauges arrived 2day only problem is i havent got a clue where 2 put the senders
The first gauge is water temp,
it looks like the temp sender thats already in the block, is their anywheres i can put it?
The second is 4 oil pressure,
any body got any ides
The oil pressure sender will tee off the side of your block where your existing oil pressure switch is - you will need to purchase some sort of tee adaptor.
The temp sensor will need to find a new home tapped into thermostat housing or adaptor teeded off from the head.
I guess it is deciding where you want to measure the water temp.
Any one else got any ideas??
Originally Posted by Tev
yer thats what i was thinkin it looks kinda identical 2 the sender thats in the block, may b bigger but i dont wanna loose the use of the dash tempgauge, i was thinkin i may b able 2 run both gauges off 1 sender bout i aint sure if it will work
As for the oil one im not sure tbh
i think thats what im going 2 try, fingers crosed havin 2 gauges hooked up 2 1 sender wont give a false readin
i was lookin at the oil feed 2 the turbo last night, i may b able 2 T off that, sure car wise make a T for gauge fittin
i had this problem i left the temp sender alone and fitted a hose adaptor in the top hose you can get these from burton. i didin't really have a choice because i got mine from america and it was a 5/8 unf it was a pain in the arse to find it all right size parts. i put it between the swirl pot and the rad. under the boost hose so you dont really see it. i think you can get a t piece for the oil pressure but i have not got round to that one i just un plugged the dash one. hope this helps
AUSTRIA
I also used a t-piece in the top coolant hose to fit the sender for my external water temp gauge
So the original sender ist still connected to the dash tempgauge and works
AUSTRIA
is your oil pressure sender equipped with an extra pin for the oil pressure switch? Mine has one so I just removed the original oil pressure switch and fitted the sender there.
Now the original pressure switch AND the new oil pressure gauge are BOTH connected to the new sender.
If you don't have a sender with an extra pin to connect the original switch, you could also buy a t-piece for that!
It's a standard thread (i don't remember the correct size but I'm sure it's an NPT thread - I will have a look on the workshop manual)
A mate bought his t-piece from a big industry-machine company, they said these are standard for hydraulic lines on big machines.
So I guess it won't be that hard to get one...
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
