Air Hose between T34 and standard air box filter
Hi
I have a 2wd Sapphire and I am in fitting T34 turbo charge.
Have you a tip to install air hose between air box filter (diameter 60 mm.) and T34 (diameter 70 mm.) ?
(no dump valve on this side)
Is this hose exist ?
Or may be, is it possible to install Escort air box filter ?
Thanks.
Claude
Thanks.
Claude
you can get a 70mm - 60mm silicone reducer ( ebay) you will also need a small length of 60mm metal tube to connect the reducer to your existing hose allowing you to use your original airbox. You will find you need to trim the hose a little to get it to fit without kinking.
CheeRS, Mike
CheeRS, Mike
Claude sorry no,contact one of the rs/xr breakers or look here
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
cheeRS stu
cheeRS stu
Cheapo way is to cut the orginial hose and slide it onto the air filter lid then put the t34 hose on top. Works a treat.
Or get a reducer hose...or get a Creative Carbon air box lid.
For the moment, i fitted original air hose Escort with part of original Sapphire hose cutted. Good solution.
Regarding Creative Carbon air box,
How much is it ?
Where can I found it ?
Thanks
Claude
kosienutter
31
22-08-2015 09:55 AM
track.focus'd
12-08-2015 05:53 PM
Escortdriver1
05-08-2015 12:45 PM
