Fully Rose Jointed Rear Suspension Kit Mk3/4 also Zoo Motorsport Adjustable Tie Bars
Old 25-07-2016, 09:39 AM
B16CVH
B16CVH's Avatar
Default Fully Rose Jointed Rear Suspension Kit Mk3/4 also Zoo Motorsport Adjustable Tie Bars
NEW - Up for sale is a fully rose jointed rear suspension kit for any Mk3/Mk4 Ford Escort. Rose joints are the heavy duty PTFE lined versions not the cheap & nasty versions so should last a long time.
The kit replaces the standard wishbone and all bushes with 4 bars that allow for the rear wheel angles to be adjusted. (Toe & Camber)
These will only work if you are using coil-over suspension since the old wishbone that carries the spring will no longer be needed.
These kits revolutionise the handling of any Mk3/4 Escort.
Kits are brand new and come with all the hardware for easy fitment.
£400
Also for sale are two Zoo Motorsport Adjustable Tie Bars. Bars have been newly powder coated in gloss black and come with 2 brand new cone links to connect to the stub axle and 2 New Kevlar lined rose joints. NOW SOLD
These allow the rear wheels to be adjusted back and forth and shorten/lengthen wheelbase.
£150 SOLD
Rear Tie Bars.
Old 25-07-2016, 03:22 PM
Beach
Beach's Avatar
£400
Message me some pics I'll grab this if it's all good and looks ok. Cheers mate
Chris 07966058391
Old 08-08-2016, 10:57 PM
boeb
boeb's Avatar
Are u making these m8 as noticed few ads here and there..also can these be adapted to run rear roll bar
Old 09-08-2016, 08:41 AM
B16CVH
B16CVH's Avatar
Hi there, I had these made many years ago but never got round to selling them. I'm having a clear out so once these are gone that's it, there won't be any more. They could be adapted but you would need to lock the two bars together otherwise they will twist. To be honest if you are running coil overs you won't need the ARB. I have seen pictures of somebody using a different roller bar altogether and linking it to the cone link on the stub axle. Regards
Old 11-08-2016, 07:17 AM
B16CVH
B16CVH's Avatar
Now £125 for quick sale
Old 14-08-2016, 09:39 AM
B16CVH
B16CVH's Avatar
Tie bars now sold
Old 25-02-2022, 04:57 PM
B16CVH
B16CVH's Avatar
Default Fully Rose Jointed Rear suspension kit for mk3/4 Escorts
Hi all,
I will soon have another batch of 20 sets of the adjustable rear rosejoint kits if anyone is interested.
Old 25-02-2022, 04:59 PM
B16CVH
B16CVH's Avatar
Chris 07966058391
New kits will be available soon 👍
Old 27-02-2022, 06:31 AM
BlakeMoyle
Wish I had more time!
BlakeMoyle's Avatar
how much will they be mate 👍🏼
Old 27-02-2022, 06:55 AM
B16CVH
B16CVH's Avatar
Hi Mate, you'll be looking at £699 for the full kit which will comprise of:
4 powder coated traverse bars with treated threads (2 each side replacing the swing arms)
2 powder coated tie bars with treated threads (1 each side replacing the tie rods)
2 cone connectors to link the tie bars to the bottom of the stub axles.
4 longer bolts (inner chassis & stub axle)
All spacers required to keep traverse bars parallel (yellow zinc passivated)
Stainless washers
12 Heavy duty Kevlar lined rose joints with half nuts
Specific settings for the suspension when fitted (toe/camber).
Regards
Danielbetty
14-03-2016 10:55 AM
James Porter
22-02-2016 10:42 AM
foreigneRS
15-12-2003 01:38 PM
Windle
14-12-2003 11:02 PM
Quick Reply: Fully Rose Jointed Rear Suspension Kit Mk3/4 also Zoo Motorsport Adjustable Tie Bars
