1.7 injectors in a puma 1.4
Hey there everyone
As my title says i ve recently trade some parts i had for the injectors. I was very happy with the trade but. The car isnt. At 4500 rev he just stop reving. Its like the ecu just cuts the fuel. I need some help to solve this
If the 1.7 injectors are larger than the ones from the 1.4, the engine is overfueling.
Why did you change the injectors? Any other changes?
the 1.7 injectors are flowing to much as the ecu thinks there stock injectors, To correct this you would need a remap or a piggyback ecu but all it will do is drop the flow back to stock meaning $800 and your still at sq 1 with the same power. Best thing to do is refit old injectors before you damage the engine..
As for mods if i was you upgrade to a 1.6 engine, needs very little to upgrade and very cheap.
deathrider666
28-09-2015 06:12 PM
