Mk5 fez exhaust on a 1.7 puma?
22-04-2013, 09:25 PM
As above, will the exhaust from a mk5 fez zetec s fit my 1.7 puma?
23-04-2013, 12:22 AM
23-04-2013, 07:07 AM
Cool cheers, I thought so but I did hear somewhere the tail pipe was too short but looking at pictures they look the same
23-04-2013, 10:50 PM
you can fit fiesta systems to pumas and vice versa
24-04-2013, 11:05 AM
Shit you are right. The tail pipe on the puma is longer than the fiesta ones.
fitment wise there the same just puma tips are abit longer.
24-04-2013, 06:08 PM
Do we know what the difference is?
24-04-2013, 06:10 PM
Ben
The exhaust will stick in further on a Puma if it's came from a Fiesta as obviously the body is different.
24-04-2013, 06:15 PM
But if it's not too much, might be able to get away with it
25-04-2013, 11:56 AM
Quote:
Originally Posted by
s6boy1979
its about 30-50mm at most
25-04-2013, 12:00 PM
Might be worth a try if I can get one cheap enough
25-04-2013, 01:47 PM
i've had both cars and had exhausts from the puma on the fiesta and vice versa
i have an exhaust on ebay going cheap
25-04-2013, 01:53 PM
Did it all fit ok? What is it and how much?
25-04-2013, 02:30 PM
25-04-2013, 02:34 PM
25-04-2013, 07:06 PM
Moderator
hows the puma coming along Ian ?
25-04-2013, 07:17 PM
Getting there Steve, fitted the lowering springs and the rear spacers the other week so its sitting nice now. I did bust one of the ABS sensors though so had to replace the complete rear ABS loom which was a bit of a pain. Going to put the 17's I have on the cab on it this weekend. Just want a cheap exhaust and air filter for it now then i'm happy. Need to sort the fuel gauge issue out though but not a clue what it is.
What you smoking around in now?
Can you txt me the number for that guy that doe the mobile body work as I have a few people at work that want to get some dents and scratches sorted? Cheers
03-05-2013, 08:53 PM
Does any1 know if the black rocker cover will just replace the silver one? Easier to paint you see, thanks
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Cosnada
07-01-2016 05:30 PM
01-11-2015 06:53 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
youngben
27-09-2015 09:37 PM
