Aircon leaking in footwells
19-09-2012, 04:20 PM
Anyone else had the problem where after the aircon has been on it leaks in the driver and passenger footwell?
Not the heater matrix and only ever happens when I have the aircon on.
Any help would be appreciated
19-09-2012, 04:44 PM
Resident Wrestling Legend
the drain is blocked from the bit inside the car that does the cooling
not too clued up on how they are set up but that's the reason it's getting wet
20-09-2012, 07:08 AM
Thanks mate, i will have a look
20-09-2012, 09:05 AM
As above, sounds like the drain tube is blocked.
20-09-2012, 09:59 AM
I'm sure, there is a drainage tray under the evaporator, which is like the heater matrix but it cools, condensation drips into the tray and drains out through the drainage hole which comes out under the car. The hole is probably blocked.
20-09-2012, 01:25 PM
Thanks for all your replies
timsrs
13-11-2018 11:48 AM
Fudgey
21
30-09-2015 06:19 PM
wheelwizardrefurbs
21-09-2015 06:42 AM
talon1
15-09-2015 10:27 AM
BRAMMER
15
14-09-2015 08:52 PM
2001 ,
air ,
con ,
footwell ,
footwells ,
ford ,
heater ,
leaking ,
matrix ,
mondeo ,
puma ,
repair ,
video
