Ford Puma Discuss the Ford Puma here!
Ford Puma Brakes
Old 19-06-2012, 07:00 AM
STURS2
STURS2's Avatar
Cool Ford Puma Brakes
Ladies and Gents,
I appreciate there are probably tonnes of threads here re brake recommendations but I am selfish and looking to get some first hand answers.
I purchased a Puma to use for a bit of spinting on a budget. I am wondering what the latest recommendation for brakes would be without changing the current wheel or going too silly with hub modification etc?
I have seen Fiesta ST suggested and others saying that standard disk (larger size, its a W reg) along with top pads (not sure which) with a good fluid will suit.
TIA
Stu
Old 19-06-2012, 07:04 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
i used mk3 mondeo callipers and st170 discs on mine.
you have to drill the hub bolt holes out to 13mm and shave a slight bit off the callipers top and bottom, but they are pretty brutal now.
i also dont have any fancy pads in them, just what came already in the callipers so with a decent set of pads you can have a rather cheap brake upgrade.
as for fluid i used castrol srf stuff.
Old 19-06-2012, 07:15 AM
STURS2
STURS2's Avatar
Thanks for that. I was wondering if anything would do without drilling and modifying what is there. Do you find the braking force on what you have excessive or just enough?
How do you mean 'pretty brutal'? Difficult to modify?
Old 19-06-2012, 07:47 AM
cos 4x4
cos 4x4's Avatar
If your putting them under 15" then you'll have to grind the calipers if you use 16" and over then they will go strait on but you will have yo drill the hubs. If you look on eBay my brother sells the complete kit on there with what ever disc and pad combo you require and includes the calipers ground down as well
Old 19-06-2012, 07:53 AM
cos 4x4
cos 4x4's Avatar
He also sells them on the fiesta zetec s forum
Old 19-06-2012, 07:55 AM
Dal_
Dal_'s Avatar
Fiesta ST calipers and discs (280mm) are the biggest Ford ones you can fit without having to drill the hub bolt holes out.
Old 19-06-2012, 08:37 AM
STURS2
STURS2's Avatar
Thanks for help chaps. Do you have a link to ebay page?
Anyone with experience of fitting these? How have you found the ST ones? I am sure anything would be an improvement from the current shite!
Old 19-06-2012, 02:17 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
the std puma brakes are piss!
of course you can never have too much braking force, but they seem to do the job. i tracked my puma at combe last year on the rs day and the brakes were well up to the job, just a shame the car was so slow lol
as for what i mean being brutal, when i first fitted them i kept stamping on the brakes and getting the abs cutting in all the time as the original ones were so poor i had to stamp on the pedal, but now im used to them its all ok lol. but they do pull up well if you need them to.
the st170 disc is 300mm and to fit them under the std puma wheels a bit of the calliper needs to be ground off on the top and bottom edges, you will see whats needed when trying to fit the wheels.
also you will have to have the wheel weights on the back of the spokes etc as there is not enough room on the inner part of the wheel.
the std hubs are easy enough to come by as they are the same as a mk3 fez, so drilling the bolt holes out wont be much of an issue should you want to refit the original ones for some reason and need new hubs.
Old 19-06-2012, 07:45 PM
cos 4x4
cos 4x4's Avatar
hi mate he doesnt have any for sale on ebay at the mo but if you register on the zsoc website he always has them for sale on there
Old 13-05-2013, 07:25 AM
Djordje Disic
Djordje Disic's Avatar
Default ford puma
Ok i have standard ford puma aluminium wheel
http://www.mondeospares.co.uk/ekmps/...001-1567-p.jpg
So is any problem if i put Mondeo Mk3 Calipers & Carriers,
Mondeo Mk3 Brake Pads,Focus ST170 300mm Discs?? Is this alu wheel ok for this Discs?
And important question what about ABS? Working or not corect???
Old 13-05-2013, 12:20 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Same wheels i had on mine mate. you will need to grind a bit off the top and bottom of the calliper to get the wheels on, but it is well worth it!
yes to the above parts mk3 mondeo callipers and pads, st170 discs. i would also hange the brake fluid while doing it.
as for the abs, yes that still works.
Old 14-05-2013, 01:22 PM
Straight_4_N/a
Straight_4_N/a's Avatar
Fiesta st setup is the only setup that will fit without changing any.
Pros there focus st170 caiplers so lots of pads and there a direct fitment and will fit under stock 15s.
Cons there the most costly setup and thay run 20mm smaller discs.
mondeo/focus setup. second bigest conversion you can get cheap does need work to hubs and caiplers if you want to run oem 15s.
Pros Cheap to get hold of and good braking and lots of pad choice if you use focus one.
Cons you have to redrill the hub holes out to 12mm and you will have to grind the caiplers down if you want them to fit under 15" oem wheels.
Old 14-05-2013, 04:19 PM
Djordje Disic
So you want to say that if i want to put Focus st170 calipers and 300mm focus st 170 discs i dont need to drill the hole and dont need to grind the calipers?
I think that ppl put mk3 mondeo calipers because are bigger and stronger.
Old 14-05-2013, 04:27 PM
Djordje Disic
ST170 calipers are more expensive then mk3 mondeo. I find mk3 calipers (2pcs) for 40e.
But st170 are more expensive and u cant find it easy like mk3 mondeo one...
Old 14-05-2013, 08:57 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
But if you do drill the hubs, puma hubs can be had for peanuts if for some reason you ever want to put the standard brakes back on.
So cant see why you wont go for mondeo callipers..
Not the best pic
Old 15-05-2013, 05:12 AM
Djordje Disic
What discs and calipers is on your picture? I dont wont to go to mondeo calipers. Think that ppl put it only because mondeo calipers are more cheaper then st170.
yes i know if i drill the hole i never can back old parts. So what do you want to say. What is best combination to put on car?
Not the best pic
Old 15-05-2013, 12:31 PM
Straight_4_N/a
No focus st and fiesta st use the same caiplers but use diffrent size carriers so thay will fit the diffrent size discs, As for grinding the calipers the focus st calipers dont need as much grinding as the mondeo items.
No its just because you can pick up mondeo calipers for £20 to £30 a set where focus st ones are £50 to £80 a set.
Old 15-05-2013, 12:35 PM
Straight_4_N/a
you can refit the old puma cailpers if you just buy 4 sleaves to fit in the holes there 50p each.
Old 16-05-2013, 07:45 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
good point on sleeving the holes!!
ok, in my pic above its mk3 mondeo callipers and pads, drilled hubs and focus st170 front discs.
the braking performance was very good, i was using the pads that were in the callipers and took the puma round castle combe for the rs day a few years ago, i got in 7 sessions and not once had any brake fade, and outbraked a few cars.
i paid £30 for the callipers and already had the discs/brake fluid. so for me was a very cheap and very effective brake upgrade.
Old 16-05-2013, 06:20 PM
Djordje Disic
u put some Wheel Spacers or not?
i paid for the callipers and already had the discs/brake fluid. so for me was a very cheap and very effective brake upgrade.
Old 17-05-2013, 07:14 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
No. Only the callipers and discs
Old 04-09-2013, 10:07 PM
Im tempted to do this mod.
Are all the mk3 mondeo calipers the same.
Old 17-10-2013, 09:06 PM
Bought some mondy calipers. I just need some discs now.
Old 18-10-2013, 12:19 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Glenn, pretty sure all mk3 mondego use the same calliper, from 1.6 to st220 etc
euro car parts for the pagid discs
Old 19-10-2013, 06:13 PM
Im sure the calipers are all the same. I bloody hope so lol.
Do you have to grind much off the calipers to get the srandard wheels to fit.
Old 19-10-2013, 10:38 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Just a bit of the top and bottom edge really. I fitted the callipers then tried to fit the wheels and removed as necessary.
Just rake the corner off really
Old 20-10-2013, 08:09 PM
Cool.Will wait till next month and I will buy some discs then fit the lot.
Did you change your back brakes from drums to discs??
Old 20-10-2013, 08:18 PM
Straight_4_N/a
Rear discs are just for looks and you have to turn them down so much thay barly touch the discs, Just upgrade your std wheel cyclinders to granada ones and thay will be better without wasting time and money.
Ive got rear disc conversion and i went out and Spent £150 renewing my rear drums instead of just fitting the discs.
Old 21-10-2013, 04:13 AM
Granada wheel cylinders??? From which granada. I take it they are bigger.
Old 21-10-2013, 06:44 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
I left the rears alone, the front upgrade was more than capable for the car
Old 21-10-2013, 06:54 AM
dojj
Resident Wrestling Legend
dojj's Avatar
When you stick then on and try them you wont worry about the rears
Best mod you can do
Old 21-10-2013, 11:16 AM
Cool replys lads. Thanks...
Old 21-10-2013, 09:28 PM
Straight_4_N/a
Fitment on most fords are the same you just have to get the ones that match your base plate, I picked up two bolt type granada wheel cylinders which iirc are 2mm or 3mm bigger than fiesta wheel cylinders. iirc fiesta are either 16mm or 17mm where granada ones are 19mm. Iirc thay was granada non abs wheel cylind3rs.
Old 22-10-2013, 03:32 PM
Ok thanks for that did you notice any difference when you fitted them.
Old 11-03-2019, 06:52 PM
dojj
dojj's Avatar
Is there a link to that brake thread you did Glenn?
track.focus'd
12-08-2015 05:53 PM
Ben26
11-08-2015 04:19 PM
10-08-2015 12:08 PM
Quick Reply: Ford Puma Brakes
