fault code - octain pin ford puma 2000 (twin lambda tyoe loom)
All
Does anyone have any idea what the fault code showing octain pin self adjustment out of range relates to on a ford puma post 2000 loom relates to.
As far as i was aware there was no octain adjustment (like you have on vauxhalls) pins in these looms, if there are where are they located?
Would this be related to having the 2 lambda sensors and no mileliminator on the car with a 4-2-1 fitted?
The car runs fine and does not suffer from any lack of power or hesitiation and revs free.
Any info on this would be good!
