advice on a puma 1.4 going to buy key lost
going to buy a puma 1.4 getting for a cheap price as the keys been lost,also the engines nocking and going to have to replace the cars going to cost me £250,any one advise me what engine will go in them and anything about replacing the key thanks peeps.
Best bet is just whacking in a 1.7. Make sure it's come out of a similar clocked car. i.e Analogue/Digi.
If bottom end of 1.4 is knocking, not even worth replacing bearings, just bin it.
the bottom ends deffo gone they have it started on another key but carnt lock doors,was just going to pit another 1.4 in been offered one out of a fiesta 1.4 for 175 suppose to be the same.
Carbon Crazy
you saying the engine starts but the central locking wont work???? if so you already have a pats transponder for the car. does the key manually open doors and ignition??? if so its just the remote thats failed, probably battery or maybe the alarm module has died. (alarm is independant from PATS).
what he told me was the car came in for a mot and the key was lost so he had to buy it of them,the bottom end was nocking already so he got a seconhand one which he put in but that nocks to ,he got a key may be with that engine but he told me not to lock doors as he couldnt open them.doesnt have alarm button with it as its lost to.
Carbon Crazy
take out the door lock barrel, dismantle it and work out the tibbe code then get a new door/ignition key cut. Then look up the remote programming sequence.
regardless of the status of the remote key, you will always be able to lock/unlock manually as long as you have the matching key.
Carbon Crazy
what is this key you have attached to??? is it a plain key or a 2 button remote???
You dont need a remote to lock/unlock the car as long as you have the right key.
Good guide to the ford/jag tibbe key system: http://www.fordscorpio.co.uk/doorlockbld.htm
well got the key and brought it home need to mot it and just give it a quick clean engines bottom ends nackered but will fix soon ,bargain for 250 pound.need to sort the alarm as i have no alarm fob.
bean offered a 1.4 06 engine to go in it how do i know which engine will work with it mines a s reg,anyone help.just in case he only had the engine no ecu with itor wireing
Carbon Crazy
erm so what keys do you have and what does what
It looks like a S plate which makes in an early puma with a 2 button infrared alarm system.
You dont need the remote to operate the alarm. Turning the key in door will do just the same. for example if you want to deadlock it, turn key to unlock just before turning to lock and it will dead lock and flash indicators which tells you the alarm is working.
yeah warren it a 1.4 out of a fiesta 06 car ,only got engine tho,got the two keys i have already set the alarm off but didnt know how i did it thanks for the great advice as how to alarm it,
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Ben26
27-08-2015 08:56 PM
rst-s1
23-08-2015 07:56 AM
Daisychain
22-08-2015 08:12 PM
