Mk 4 Mondeo Titanium X intermitent heavy steering
Old 22-09-2015, 01:53 PM
dange
dange's Avatar
Default Mk 4 Mondeo Titanium X intermitent heavy steering
Hi guys,
got an intermittent problem that started after going through a puddle with the o/side front wheel, steering went very heavy as if the power steering had failed but after stopping restarting engine it was fine this was a few months ago.
recently noticed that whilst parking car in multistorey carpark again the steering went very heavy at tickover but came back normal
this has happened on 3 occasions in the last week
car is a 2008 with 177k on clock it is serviced regularly
advise please on where to look 1st
thanks Dangermouse
Old 22-09-2015, 07:13 PM
RichieST
RichieST's Avatar
The filter inside the power steering reservoir is probably blocked. Look at the reservoir, it is probably wet around the outside and the fluid will be foaming when on tickover. Quite common on Mondeos.
If so, drain the reservoir and remove. Either clean the filter inside it or replace it, I changed mine recently, think it was £18 for a brand new one, plus a litre of fluid to top it up again.
Look at page 5 of my thread, you will see what I mean. https://passionford.com/forum/restor...-on-20s-5.html
Old 23-09-2015, 07:21 AM
dange
dange's Avatar
Thanks RichieST youre a star
Old 23-09-2015, 12:11 PM
RichieST
RichieST's Avatar
No problem. If you get a new reservoir and it comes with a green piece inside it and the one you take off the car doesn't have it then take it out of the new one.
mark94
10-10-2023 06:52 PM
wowk
30-03-2021 07:49 PM
tankybaby66
06-02-2016 02:24 PM
Brickhouse
14
03-10-2015 07:28 PM
The Enigma
29-09-2015 10:31 AM
Quick Reply: Mk 4 Mondeo Titanium X intermitent heavy steering
