PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Mondeo (Including ST)
Register Forgot Password?
Register Photos KBase Gold & Trader Accounts FAQ Search Today's Posts Mark Forums Read GarageVendors
Search
Welcome to PassionFord
Ford Mondeo (Including ST) This forum is for discussion of all things pertaining to the Ford Mondeo range of cars.
submit to reddit
Old 30-04-2012, 01:59 PM   #1
deathrider666
deathrider666's Avatar
Trader Score: (0)
deathrider666 is on a distinguished road
Default Mondeo TDCI Belt Tensioner Pulley
Trying to change the alternator on my 2002 TDCI, I've managed to get the old one off but only managed to get the tension off the belt by undoing the bolt by the bottom of the alternator (it's the tensioner which is like a V shape with a pulley each end and a pivot point in the middle not the easier looking type which has the tensioner easily accessible at the bottom of the engine).
When I get the new alternator on, can I move the tensioner without buying a special tool that I've read about? Which way does the tensioner move, clockwise or anti?
deathrider666 is offline   Reply With Quote
Old 30-04-2012, 02:46 PM   #2
NEEDFORSPEED
Trader Score: (0)
NEEDFORSPEED is an unknown quantity at this point
i normally just use a prybar on the tenioner never had an issue just be carefull not to crack the edge
__________________
[CLICK TO SEE MY SAPH RESTO!!
http://www.passionford.com/forum/viewtopic.php?t=240033
NEEDFORSPEED is offline   Reply With Quote
Old 30-04-2012, 04:35 PM   #3
deathrider666
Trader Score: (0)
I've tried to get a crowbar on it and lever it against the engine mount to push it clockwise (near the bottom pulley) and anti clockwise (near the top pulley) but doesn't seem to move.
Which way is it meant to move?
Old 30-04-2012, 08:46 PM   #4
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
Trader Score: (1)
DanW@FastFord has a spectacular aura aboutDanW@FastFord has a spectacular aura about
It's a tricky one, and is definitely easier with the correct tool. Some people have made up a socket to fit, but you may find it easier to get the tool and sell it on eBay after.
__________________
www.fastfordmag.co.uk
DanW@FastFord is offline   Reply With Quote
Old 30-04-2012, 09:32 PM   #5
NEEDFORSPEED
Trader Score: (0)
OR put the belt on but off the top middle guide pulley and push the belt down onto it
__________________
Old 01-05-2012, 02:52 PM   #6
DanW@FastFord
Spelling Club King!
Trader Score: (1)
It's easiest as a two person job, and even with the tensioner 'untensioned' it's still a tight fit!
__________________
Old 01-05-2012, 06:50 PM   #7
plumbobing
Trader Score: (0)
plumbobing is an unknown quantity at this point
This is my next job for this week end, i can't be bothered to struggle with some dodgey tool so for £15 i couldn't say no to buying the proper tensioner tool.
One thing i would like to know though is the torque settings for all of the components of the auxiliary belt setup. Does anyone have any info on these please?
plumbobing is offline   Reply With Quote
Old 02-05-2012, 04:55 PM   #8
GVK.
GVK.'s Avatar
Trader Score: (0)
GVK. will become famous soon enough
Correct way of doing it is to remove the alternator, then the support bracket complete with the tensioner , swap the tensioner then refit the bracket etc.
Some people may 'cheat' by undoing the tensioner off the bracket in situ, but there is little room to get an Allen key in there to undo the bolt.
Alternator comes out between chassis and subframe once os track rod end is undone.
Alternator lower mounting studs 15nm
Alternator nuts and top bolt 47nm
Track rod end 40nm
Alternator support bracket - block bolts 47nm
Tensioner retaining bolt 23nm
Tensioner to alternator support bracket bolt 55nm
Idler bolt 48nm
Crank pulley bolts 45nm + 120 degrees.
BEFORE you take the belt off draw a picture of it's routing and note how the tensioner sits in the bracket as if you get it in the wrong place you won't get the belt on
__________________
Gary.
GVK. is offline   Reply With Quote
Old 03-05-2012, 08:33 PM   #9
DanW@FastFord
Spelling Club King!
Trader Score: (1)
Quote:
Or you'll spend bloody ages getting the braket back on only to realise that you haven't routed the belt through it, so have to take it all off again!
__________________
Old 03-05-2012, 08:43 PM   #10
GVK.
GVK.'s Avatar
Trader Score: (0)
Exactly that!
__________________
Gary.
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
