mk1 1600 gearoil change?
i have a 1600 mk1.5 focus ...best i can see from looking online/haynes its doesnt have a drain plug for the gearbox?
is that right
also thinking it might well need clutch soon , which i would get a garage to do , would i be best to leave the oil and ask them to refill it ? i assume they could tip the box on its side and let most of it out of the driveshaft holes?
is there any prefered gear oil for these ? or all much the same as long as its the right grade
is that right
ffoc.co.uk
Ask ford for the oil 10w75 or something I'm not sure so don't quote me.
There is a drain and filler under the plastic section on the front of the gearbox. A 7mm hex head opens the filler and a mole grip opens the drain plug.
