Ford Focus TDCI 1.8 2002
Hello
I was wondering if anyone could help me. I'm having issues with my Ford Focus. I started my car and reversed of my driveway and then when I changed gear and put it into first, then car cut out. I went to start the car again and it wouldn't start.
When trying to start the car the engine sounds fine but it just won't full turn over
If anyone could help it would much appreciated
Thanks you
Luke
Thanks you
Luke
hi mate, first thing i would check is the spark plugs give them a clean if you can and then check the HT leads and the coil pack make sure everything has good connection....
last case ive heard of this was a fuel pump dead...
not sure about your but when you first turn your ignition can you hear like a pump noise or a sound when you turn your key to where all the dash light come on?
Versus_Creations
25-10-2015 06:45 PM
DAN@ADRIAN FLUX
37
20-09-2015 10:38 AM
