St170 holding back up the rev range updated with pics (29/5/16)
Old 14-05-2016, 01:23 PM
  #41
RichieST
RichieST's Avatar
That's good! It definitely sounded fuel related. Glad you didn't change the pump first just to find it wasn't it!
Old 14-05-2016, 04:17 PM
  #42
Moderator
STeve's Avatar
keeping them crossed for you glenn
Old 14-05-2016, 05:00 PM
  #43
Yeh hopefully ive fixed it lads.
Old 14-05-2016, 06:10 PM
  #44
big_wasa
big_wasa's Avatar
I've changed the pump driver modual and never coded them ?
Old 14-05-2016, 08:14 PM
  #45
Was yours ok when you fitted it then.
Old 20-05-2016, 11:19 AM
  #46
Ive just been out in the car today and its still the same. I found out by trying to overtake a tractor lol.
Looks like im on the look out for a fuel pump.
Old 20-05-2016, 11:37 AM
  #47
Would this pump be ok
http://www.ebay.co.uk/itm/3217739806...&ul_noapp=true
Ive looked on the net and this pump seems to fit all petrol models and other fords.
Old 25-05-2016, 05:17 AM
  #48
Bloody engine light came on this morning. Ive never known a car like this ha ha ha.
Old 25-05-2016, 07:38 AM
  #49
big_wasa
big_wasa's Avatar
It wasn't broken to start with but it didn't make any difference.
Old 25-05-2016, 08:05 AM
  #50
Moderator
STeve's Avatar
still points towards imrc glenn if not fuel related, weird one
Old 25-05-2016, 12:14 PM
  #51
big_wasa
big_wasa's Avatar
At least you have a code to look at now.
Old 25-05-2016, 03:36 PM
  #52
The code is P0133 O2 sensor slow response bank one sensor one.
Im thinking if the engine isnt getting enough fuel is the lambda sensor picking up that the engine is running lean??
My fuel pump came today so i will have to run the fuel down so i can change the pump.
Old 25-05-2016, 07:04 PM
  #53
RichieST
RichieST's Avatar
Slow response generally means the lambda sensor is fooked. Check the wiring to the pre cat sensor and make sure the pins inside the wiring plug aren't corroded. I had to put one on my old st170 for the same fault, quite common on these too apparently.
Old 25-05-2016, 07:18 PM
  #54
big_wasa
big_wasa's Avatar
Front o2 is very common.
Old 26-05-2016, 08:37 AM
  #55
The light didnt come on yesterday going home and it didnt come on this morning coming to work.
I made a bracket for the sensor a few months back cause the sensor was just lying on the bell housing.
Old 29-05-2016, 02:04 PM
  #56
I got time to look at the ST today.
I know its a bit gash cutting the floor but imo its easier than dropping the tank cause ive done one of these before.
The filters in the sending unit and on the bottom of the pump were bogging.
Bottom of the sending unit.
I used a few cans of brake cleaner to clean the filters.
I replaced the fuel pump and rebuilt the car.
When i put the fuel pipe back in i fooked the seals. Luckily i had some rubber o rings in my garage.
I took the car up the road and kicked its fooking head in. I think its cured now cause it pulls right through the rev range in all the gears.
When i get back to work im gonna make a plate to go ovwr the hole.
Old 29-05-2016, 02:23 PM
  #57
RichieST
RichieST's Avatar
Bodging bastard
Hope you've got it sorted now mate!
Old 29-05-2016, 02:53 PM
  #58
Moderator
STeve's Avatar
christ !, I break these and that has to be the dirtiest pump I have seen to date,
Old 29-05-2016, 03:40 PM
  #59
Pitbull69
Pitbull69's Avatar
Ill be honest, mine was just as bad if not worse when I had mine changed, but I purchased my pump from Burton, and it came with new filters, glad its all up and running again mate, these cars can be tempremental,
Old 29-05-2016, 03:44 PM
  #60
Originally Posted by RichieST
Bodging bastard
It will be right lol. Its only a 600 quid banger with 125k miles on it ha ha.
Old 29-05-2016, 03:45 PM
  #61
Yeh its bogging isnt it. When i changed the fuel filter the other week the fuel that came out was brown.
Old 29-05-2016, 03:47 PM
  #62
I bought the pump in the above link. I dont like spending good money if i dont have too.
Old 26-06-2016, 10:35 PM
  #63
JC600
JC600's Avatar
Glenn, did you sort this out? As mines started doing the same thing now.....about 3.5k.....but not all the time. It's had a new fuel filter. It was stood a while before I brought it, that's why I got a full service. Put full petrol system cleaner in today, so going to take it for a long run tomorrow.
Old 27-06-2016, 11:38 AM
  #64
JC600
JC600's Avatar
Think I've sorted it, cable for imrc had come off......reconnected it and took for a drive was spot on.....also got my brother to plug it in to the snap on diagnosis machine, there were 2 old codes P1518 & P1519. Cleared them, went for a run and tested again. No codes found. But never had a eml on when it started misbehaving.
Old 30-06-2016, 12:42 PM
  #65
Sorry for late reply. Yeh it did sort it but funnily enough its started to do it again.
My mate bought a cheap clio sport for spares and i took the fuel out of it and put it in the st. I think the bowser myst have put some shit in the st.
I will take the sender out again and have a look for some shit in the sender.
Ive noticed a few times when i have below 1/4 of a tank sometimes there is no power. Uts a bit like fuel surge.
Old 30-06-2016, 08:17 PM
  #66
JC600
JC600's Avatar
No probs, funny you should say that as mine started doing it when below 1/4 of a tank.....so might be a fuel pressure problem, from blockages or dodgy pump. I'm going to run mine down. Then refill the tank with another fuel system cleaner, see what happens.
Think the imrc cable coming off was just a coincidence. It's deffo a fuel problem.....nothing on the diagnosis, so could be a blocked pipe or injector. Hopefully the system cleaner will work.
Also noticed I've got no jubilee clip on my intake hose to throttle body, so need to put one on.
Only thing is I'm on call for a week now, so can't drive it lol
Old 01-07-2016, 06:18 PM
  #67
I took my pump back out and it 2as full of shit again. Cleaned it out and the car is running sweet as a nut.
Old 01-07-2016, 07:01 PM
  #68
JC600
JC600's Avatar
Cool, I'll see how mine goes once the system is cleaned out.....it's had the fuel filter changed. Think it must be picking crap off the bottom of the tank when low.
Old 04-07-2016, 05:04 PM
  #69
I changed my fuel filter first matey and it was no better. The fuel that come out of the filter had a orange ting to it
Old 04-07-2016, 07:23 PM
  #70
JC600
JC600's Avatar
Spoke to my brother today, and he said the fuel was quite clean when they changed the filter......Can't drive it till the weekend, so will let you know how it goes. Must put that jubilee clip on the throttle body first.
Old 09-07-2016, 09:24 PM
  #71
JC600
JC600's Avatar
Took it out today, about 35 miles......drove absolutely spot on, all the way through the rev range.
Old 11-07-2016, 06:28 AM
  #72
Fingers crossed its just the fuel filter then.
So far since I've had my pump out again its been ok.
JC600 (11-07-2016)
Old 11-07-2016, 08:15 PM
  #73
JC600
JC600's Avatar
Yep, fingers crossed.
Old 15-07-2016, 09:14 AM
  #74
Well so far its still ok.
Old 16-07-2016, 03:56 PM
  #75
JC600
JC600's Avatar
Good, same here.....done about 80 miles today, and all good.
Old 16-07-2016, 08:37 PM
  #76
Im due some fuel in the car now and its still ok. The last time i had below quarter the car was playing up and cutting out.
Old 17-07-2016, 01:49 PM
  #77
JC600
JC600's Avatar
Nice one, glad yours seems to be behaving now.........I'm down to 1/2 a tank now and still behaving.....I'll let you know how it is when I'm below 1/4.
Old 17-07-2016, 09:47 PM
  #78
Fingers crossed. Ive just put another full tank in mine so i think ive sorted it.
Old 17-07-2016, 10:41 PM
  #79
JC600
JC600's Avatar
Cool, glad it's sorted.
Brickhouse
Ford Mondeo Including ST
20-07-2016 11:18 PM
purpleka
Ford KA
19-03-2016 07:46 PM
Paul_RS
07-03-2016 07:43 PM
Brickhouse
06-03-2016 02:29 PM
konceppt
06-03-2016 02:13 PM
Quick Reply: St170 holding back up the rev range updated with pics (29/5/16)
