ST170 passenger speakers keep going off.
Old 09-11-2015, 08:40 PM
Default ST170 passenger speakers keep going off.
Ive noticed a few times on my st that both passenger speakers keep going off. I can go over a bump then they will come back on.
It sounds like a loose connection to me. Ive had the passenger door card off and adjusted the speaker connection.
With it been both the passenger speakers i didnt think this would help.
Is there anything common to check before i look into it further.
Old 09-11-2015, 09:06 PM
RichieST
RichieST's Avatar
Is it both the speaker and tweeter in the front door or the front and rear nearside? Give the wiring loom between the door and the body a wiggle. Might have water in it or something.
Old 10-11-2015, 06:14 AM
Moderator
STeve's Avatar
as yours is a 3dr my feeling would be stereo wiring harness or stereo itself as sub wiring is also on n/s
Old 10-11-2015, 12:25 PM
The nsf and rear speakers go off. The sub stays on. I wondering if its in the wiring loom. I just hope its not the radio itself cause i dont really wanna put an aftermarket head unit in the car.
If the speakers stay off i will use one of my other radios to eliminate the stand head unit.
Old 10-11-2015, 12:26 PM
Richie ive wiggled the door wiring harness between the door and A pillar.
Old 10-11-2015, 12:30 PM
Moderator
STeve's Avatar
if your running the 9006 head unit glenn dont rule out it being faulty as they are a terrible HU and bloody nightmare to replace as no fooker has them
Old 10-11-2015, 03:11 PM
Yeh its 9006 matey. I hope its an easy fix matey.
I had a quick look on ebay and there isnt 1 listed.
Old 10-11-2015, 05:35 PM
RichieST
RichieST's Avatar
Try another unit in there if it works OK get yours sent off for repair.
Old 10-11-2015, 05:50 PM
Theres a radio place in my town. I will try them if it is fooked.
I heard these head units can be temperamental.
Old 10-11-2015, 06:10 PM
Moderator
STeve's Avatar
biggest issue is the 9006 is the only one built to operate the sub, these and the 6006 are dreadfull for faults
Old 10-11-2015, 08:32 PM
Or dear lol.
Old 14-11-2015, 12:36 PM
Bit of a update. I tried another head unit(sony single din) and the passenger speakers worked. I tried the standard hu in and the speakers also started to work. Ive also noticed a crackle sound coming from the bass box when turning the orginal hu on.
The passenger speakers have gone off again. I wonder if there is a fault with the wiring. When im on earlys next week i will have a better look at this.
Old 14-11-2015, 02:15 PM
Moderator
STeve's Avatar
them 9006/6006 are well known for stupid faults like that glenn
Old 14-11-2015, 11:38 PM
I wonder if they can be repaired.
Old 15-11-2015, 07:09 AM
Moderator
STeve's Avatar
anything can be repaired if you have deep enough pockets, just look on ebay for how many 6006 units are sold with errors, 9006 comes up once in a blue moon and even then if its not got the special key to lock the mechanism for transport it can arrive faulty
Old 15-11-2015, 09:46 AM
I noticed last night when i swapped from radio to cd last night it started to play through all the speakers.
Im gonna check resistance in the passenger speaker wire then run a wire from the back of the head unit to the speakers then doing this will eliminate the wiring.
Old 16-11-2015, 05:56 PM
Well ive come to the conclusion that my head unit is at fault. I checked for resistance in the passenger front door speaker wiring amd it was spot on. I even put a piece of wire in from the back on the head unit to the speaker and it still wasnt working.
Ive plugged the head unit back in and all the speakers are working for now.
I will have to see if it can be repaired and how much it will cost.
Old 17-11-2015, 05:29 AM
Moderator
STeve's Avatar
back in the day at ford we have shelves full of these head units all faulty, and used to send them back for mass repair, the HU was a good idea but cheaply made with many internal parts of poor construction but saying that there are audio experts out there with the know how to recitfy this
Old 17-11-2015, 06:18 AM
The only other thing i can think of which would be cheaper than repairing the radio and thats to run the passenger speakers out of the drivers speakers. You can buy repair multi plugs and this would mean im not chopping into the cars wiring.
Old 17-11-2015, 09:36 AM
Moderator
STeve's Avatar
problem with doing that is your changing the Ohm rating and putting HU under strain as you will only be using half the power from HU and no longer in stereo mode either as it will become mono
Old 17-11-2015, 06:03 PM
It will be cheaper than getting the head unit repaired though.
Old 18-11-2015, 05:25 PM
Moderator
STeve's Avatar
yeah but will sound pants
Old 18-11-2015, 06:37 PM
RichieST
RichieST's Avatar
You will overload that circuit Glenn as there will be half the resistance with 2 speakers on each channel , you may find it will go in to protect mode and not work at all or it will make the headunit go pop.
Old 19-11-2015, 05:51 PM
Bahhhh. Im tempted to take the head unit apart to see if i can see anything obvious.
If rhe worst comes to the worst i might just put my sony head unit in and use a amp for the bass box.
Old 19-11-2015, 06:09 PM
RichieST
RichieST's Avatar
Why not get it repaired glenn?
Old 19-11-2015, 08:14 PM
I will have to go and ask. I just like to fix things myself.
Old 19-11-2015, 08:30 PM
RichieST
RichieST's Avatar
Know what you mean mate. There's a repair shop near me called maple audio I've used them a few times. They do repairs via post so if you have no luck maybe try them.
Old 20-11-2015, 07:17 AM
Theres a place near where i live who do radios and alarms so i will have to pop in there and see what they say.
Old 26-11-2015, 05:16 PM
I think the fault with my radio is the volume nob. If i twiddle me know the sound on the ns speakers start to work. Ive been doing this for the past few days now and all the speakers work.
Old 26-11-2015, 06:15 PM
RichieST
RichieST's Avatar
There you are then. A good play with your knob fixes everything lol
Old 26-11-2015, 08:32 PM
Defo matey. Cant beat twiddling with your knob.
Old 27-11-2015, 05:34 AM
Moderator
STeve's Avatar
few quirts of contact cleaner and the jobs golden
Old 27-11-2015, 06:21 AM
Yeh ive got some electrical cleaner i will have to squirt on my knob.
g350 aar
20-08-2020 03:59 PM
Luke_ZS
06-11-2015 08:11 AM
Stokesy
01-11-2015 03:15 PM
stuart collins
18-10-2015 08:03 PM
Quick Reply: ST170 passenger speakers keep going off.
