PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Focus > Ford Focus ST
Register Forgot Password?
Ford Focus ST This forum is for discussion of all things pertaining to the Ford Focus ST Range.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 14-02-2010, 06:25 PM   #1
shunn
shunn's Avatar
Trader Score: (0)
shunn is on a distinguished road
Post st170 rear disk and pads change
hi all,
planning to change rear disks and pads in the near future. fairly compitent changed disks on previous cars fiesta and escort si's.
just after a few tips from anyone who's done the job before.
like disconnecting handbake? use of a REAR CALIPER PISTON WIND IN TOOL?
cheers
shunn is offline   Reply With Quote
Old 16-02-2010, 02:55 PM   #2
MickMc
MickMc's Avatar
Trader Score: (0)
MickMc is an unknown quantity at this point
I just did mine at the w/e albeit on a 2.0 and not a 170 , i never disconnected the handbrake cable , just chocked the front wheel and released the handbrake from inside , the carrier bolts are on there pretty good (loctited) i managed to round one , so gonna order new ones and replace them. As for the caliper , i used a Draper ABS rewind tool which worked great but i've heard of folk having trouble with the rears.
Hope all goes ok for you fella
__________________
MickMc is offline   Reply With Quote
Old 16-02-2010, 04:59 PM   #3
shunn
shunn's Avatar
Trader Score: (0)
ok cheers for that. all set for this weekend!
i'v spoke to a few people and they have all said the same, the piston on the caliper can be a pain to wind in!
i'l give it a go and see
thanks again
Old 16-02-2010, 05:04 PM   #4
.Ross.
.Ross.'s Avatar
Trader Score: (2)
.Ross. will become famous soon enough
Pretty straight forward job TBH.
Both pistons spin in clockwise, Make sure you alinge the tit on the pads with the groves on the piston.
If you havent got a wind in tool then use a G-Clamp or pointy nose pliers .. Once you break the initial stickyness the pistons should spin straight in ..
Good luck!
.Ross. is offline   Reply With Quote
Old 23-02-2010, 05:34 PM   #5
shunn
shunn's Avatar
Trader Score: (0)
job done!
changed rear disks and pads at the weekend. job went well.
came off easily and the caliper piston behind the brake pads i was worried about wound in fine!
i took my car to a local garage last month after a brake warning light eluminated, thay said not to worry evrything seems ok it must a fault on the instrument cluster, a common problem with the focus.
this light has since gone off after i changed the disks and pads.
wont be going there again!!
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
