Problems with my FRS....
Old 03-01-2006, 05:18 PM
Focus_RS1658
Focus_RS1658's Avatar
Default Problems with my FRS....
I have been having the battery light & abs light flicker on and off alot recently, also the dash lights & head lights stay dim all the time unless i put my foot down and take it above 4000rpm then the lights get bright again, but this goes dim again after a minute...
Ford said I had a faulty alternator so they replaced that checked the cabling and they said everything was fine.. Still had the same problems after they done that, now they seem to think it must be the a faulty PCM but there are no fault codes...
What do you guys think and where is the PCM located?
They asked me if it had been chipped as they said this can cause the PCM to malfunction over time....Obviously I said no..
Old 04-01-2006, 09:08 AM
belly
belly's Avatar
I ve never heard of an frs doing this before, if i was you i would remove bluefin, then do a drive cycle (80 - 100 miles). then take it back to your fraud dealer and at the service manager, or take it to a specailist who actually knows something about the frs.
Old 04-01-2006, 09:12 AM
Focus_RS1658
When it first went it they found a P1246 fault code, when I read up on this it says to check the Alternator, check PWR, check GND, check PCM...
So they assumed it was the Alternator without doing anymore tests..
Old 04-01-2006, 09:23 AM
Oranoco
Oranoco's Avatar
Send it back to them mate if the problem is still there. Ford can be quite frankly crap; at times. My local dealer wanted to charge me £300 to tell me why the ABS light was on on my S2.
Old 04-01-2006, 09:28 AM
belly
belly's Avatar
have you checked the battary, cos that been the only problem i ve had with mine, as ford put in such a puny battary as standard.
DAZZER
30-09-2015 08:43 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
Quick Reply: Problems with my FRS....
