Focus RS toe in or toe out?
does anybody know front and rear tracking settings cos Mr Ford has not got data on his brand new £8k tracking gizmo??!!!!!! Is it best to run stock settings (if known ) or has anybody got a better set up?
here you go , may be a bit late tho.
anybody tried having a set up and did it work , my car seems to follow the road a lot even off the power , thought that was generally a tracking problem
Focus RS Geometry
Front Caster 2.98 Deg ---range 4.08 to 1.88
Front Camber 0.54 Deg ---range 0.77 to minus 1.85
Front Toe-in 0.15 Deg ---range plus/minus 0.25
Rear Camber minus 1.44--minus 0.12 to minus 2.76
Rear Toe-in 0.35 Deg ---range plus/minus 0.15
Focus RS Geometry
wowk
30-03-2021 07:49 PM
