st170 6 speed gearbox in focus rs
Old 07-08-2014, 05:05 PM
gateshead
gateshead's Avatar
Default st170 6 speed gearbox in focus rs
hi i have a st170 i am breaking will the 6 speed gear box fit. i have the box and drive shafts is that all i need other then diff. any help appreciated. cheers kevin
Old 07-08-2014, 05:52 PM
CosworthGuy
3dr Cosworth owner
CosworthGuy's Avatar
You'll also need the 170 Dual mass flywheel and clutch. The 6 speed cables also at the very least and maybe the mountings. The 170 box is not a ford box. Its a getrag box. Same as on the mini cooper s
Old 07-08-2014, 06:02 PM
gateshead
gateshead's Avatar
not that simple then is it possible to get uprated clutch and solid flywheel for the st170
Old 07-08-2014, 06:52 PM
gateshead
gateshead's Avatar
does any body no if the mini cooper s flywheel and clutch would fit the st170 gearbox
Old 07-08-2014, 07:35 PM
3i Jim
3i Jim's Avatar
I've owned an st170 and thought the gear ratios were rubbish and the DMF was a pain in the arse. Personally, save your time and money and not bother.
Old 10-08-2014, 03:19 PM
gateshead
gateshead's Avatar
hay 3i jim was yours turbo charged
Old 05-03-2015, 02:41 AM
NZWINRZ
NZWINRZ's Avatar
I've had a Focus SVT 6speed, our equivalent to a ST170. I too had considered using the 6speed in the RS clone I built. The problem is the 6speed axles have a different spline, finer, smaller than the RS axles, would have to use the outer bearing and hubs, but then you wouldn't have RS wheel track/offset.
I took the c/v joints off thinking I could just swap the RS outer to the SVT axle but those spine on the axle were different too.
salsheikh
Ford Focus ST Parts for Sale
06-10-2019 07:56 PM
The Underdog
29
07-09-2015 09:49 PM
Fordmad!
04-09-2015 01:42 PM
salsheikh
Ford Focus RS Parts for Sale.
20-08-2015 12:22 PM
Quick Reply: st170 6 speed gearbox in focus rs
