Max boost on standard charge cooler?
Old 07-05-2014, 03:44 PM
series_one_rst
series_one_rst's Avatar
Default Max boost on standard charge cooler?
Hi, had a little search on google but not found much set in stone.
Will a Standard charge cooler set up of a focus RS safely and efficiently deal with 20psi boost?
thanks.
Old 11-05-2014, 07:13 AM
pee vee
pee vee's Avatar
Should be ok. Can never tell till you try. If driven Hard, obviously the charge temps will go up.
Tim B uses the standard setup with a bigger tank in the boot I think, and his gets used pretty hard.
Old 14-05-2014, 10:21 AM
alex_boy!
alex_boy!'s Avatar
Be fine mate - I'm sure there are some up to 400hp still running the charge cooler.
If its a strong unit still then you'll be fine
Old 24-05-2014, 12:02 AM
series_one_rst
Cheers! unsure as to whether I will fit one now but good to know.
Old 08-06-2014, 05:44 PM
Stu.H
Stu.H's Avatar
It's fine. Obviously CTs will rise but if it's just for the occasional blat, no issue
They soon come back down
JK12
33
26-04-2021 12:09 PM
Adam Graham
06-09-2015 06:04 AM
CrOwSoN15
14
03-09-2015 12:21 PM
StephTell
02-09-2015 06:31 PM
blackbeautyzetec
29-08-2015 02:11 PM
Quick Reply: Max boost on standard charge cooler?
