Focus rs Cams
Old 18-04-2014, 07:00 PM
Churtz
Churtz's Avatar
Default Focus rs Cams
Evening all.
Can someone confirm for me that a mk1 focus RS uses different cams to the 2.0 zetec blacktop?
Many thanks.
Matt
Old 18-04-2014, 07:20 PM
jonfoc
jonfoc's Avatar
I'm lead to believe they are the same. Use a 1.8 inlet cam for a better response
Old 18-04-2014, 08:06 PM
Churtz
Churtz's Avatar
Well I've now been assured that the 1.8 and 2.0 cams are the same. I've read that the focus rs boys use a 1.8 can for better response..... Means the frs cams must be different?
Old 18-04-2014, 08:11 PM
studabear
studabear's Avatar
I was under the impression the frs had unique cams :unsure:
Old 18-04-2014, 09:32 PM
jonfoc
jonfoc's Avatar
Having had a focus RS which was fitted with a 1.8 inlet cam, I can tell you the engine and car were completely different after fitting. So from that I can only presume that the 1.8 and 2.0 are different.
Old 19-04-2014, 08:07 AM
IanC
IanC's Avatar
The frs cams arnt the same as any other zetec there unique to the frs
Old 19-04-2014, 10:00 AM
Churtz
Churtz's Avatar
Ok cool. Next question, does anyone know the ident code for the frs cams.... They use ident rings for part numbers so its something like 01010 (standard 2.0 cam) .. OR anyone have a pic of FRS cams?
Thanks
Old 19-04-2014, 03:02 PM
IanC
IanC's Avatar
I'll see what I can find for you pal think I've got a set of cams in the garage I'll have a look when I get home
Old 19-04-2014, 09:23 PM
Churtz
Churtz's Avatar
Thanks mate!!
Old 19-05-2014, 09:07 PM
hodgebull
hodgebull's Avatar
hi looking for a exhaust cam for a frs anyone help
Old 12-08-2014, 09:09 AM
RSRick3290
RSRick3290's Avatar
Iv just bought piper cam pulleys and have a 1.8 inlet cam im putting into my FRS has anyone tried different degrees on the 1.8 cam or is std best ?
cos elle
25-09-2015 09:52 AM
BRAMMER
15
14-09-2015 08:52 PM
CrOwSoN15
14-09-2015 11:33 AM
Chopshop85
12-09-2015 06:42 PM
grishenko45
09-09-2015 12:58 PM
Quick Reply: Focus rs Cams
