help focus rs smoking
Old 15-04-2014, 01:56 PM
leeby
leeby's Avatar
Default help focus rs smoking
Hope someone can help im averagely sure its turbo seals but when car comes on boost its nice when I change gear regardless of revs and it comes on boost again I get a small puff of blue smoke (oil burn) car doesn't seem to be using oil and ticks over ans runs really well just wondering if anyone would know before I commit to spending
Old 17-04-2014, 10:18 AM
Farmer Giles
Farmer Giles's Avatar
start with the easy / free stuff first before spending..
give you're boosts pipes a clean out and while you're there you can check the seals to see if there's any obvious leaks and check the turbo shaft for play then go from there.
Also make sure any other breather pipes are clear as a blockage could be increasing pressures and forcing oil past the seals whether they are good or not.
how many miles has it done ?? might just be due a refurb on age / mileage anyway.. Turbos don't last for ever unfortunately
2p
Old 17-04-2014, 12:01 PM
leeby
leeby's Avatar
Finally stripped turbo off lastnight and visible nice new oil in compressor housing nice and black in outlet so seals definitely knackered and compressor wheel has took a hit by looks of it also so new turbo ordered
Old 06-08-2014, 03:57 PM
jammz
jammz's Avatar
Damn that sounds pretty bad. How is your car doing now?
TPM961
15-01-2018 10:50 AM
massivewangers
30
01-10-2015 07:40 PM
RSMK4TURBO
Ford Focus RS
14
19-09-2015 06:27 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
turbowag
03-09-2015 08:07 AM
Quick Reply: help focus rs smoking
