Mk1 focus rs cutting out
Old 24-03-2014, 10:20 PM
Tricky149
Tricky149's Avatar
Default Mk1 focus rs cutting out
Focus rs mk1 originally when cold would go to a very low idle almost to cut out but it now cuts out when cold or hot, start it strafing up and it fast idles but soon as throttle is touched it will rev then cut out, is there a common problem to look for, any advise greatly appreciated
Old 24-03-2014, 10:27 PM
fiesta23
fiesta23's Avatar
air leak ? check the back of the inlet manifold for split pipes
Old 24-03-2014, 11:00 PM
bigdel
bigdel's Avatar
my lad had this on his last week. cleaned out all the idle control valve and throttle body, now it idles perfectly
Old 25-03-2014, 01:51 PM
STAFFY OWNER
STAFFY OWNER's Avatar
As said above check behind the manifold and the pipes that go into the white one way valve, also can you hear any hissing?
Old 05-04-2014, 09:29 PM
Tricky149
Tricky149's Avatar
Idle control valve was the problem, thanks for the replies
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
03-11-2015 04:08 PM
hopper350
04-09-2015 12:53 AM
Ben26
03-09-2015 07:55 PM
03-09-2015 10:49 AM
Quick Reply: Mk1 focus rs cutting out
