bright green liquid
bright green liquid
I have a small minor leak from the left hand side of the bay some where.
Had a better look today when I was copper greasing my front pads
Leak is coming from a metal pipe on the drivers side but it's bright green and the water tank has pink coolent
What would that liquid be? Is this leak a common problem?
Depends if it's a crack in the pipe itself or just a seal on a joint.
Just a thought, some times coolant looks different colours, so just make sure it is/isn't ac leak or coolant.
the green stuff is tracking dye that is added when the AC is refilled...so that you can spot where there is a possible leak in the AC system.
you are supposed to use an UV light and glasses to spot the leak..as it is ultraviolet color...so ..if you can actually see that much liqiud...its a big leak.
does your AC work at all?its should not work if its a leak that big...even if the AC is missing a couple of hundred grams of AC refrigerant...the system will not work.
It's your power steering pipe they rot and leak away slowly. Take your front bumper off and look above your chargecooler rad you should notice it letting out little drops. They've made a steel one so it does not rot get one ordered before it gets worst.
Harry I noticed the leak when I took drivers side wheel off as the metal pipe can be seen from there and it was slightly dripping
Best place to get the part from is Carparts express.
focus rs 1672
focus rs coolant should be pink and has a 5 year life,the green has a 3 year life.
they cant be mixed im sure so better hope all your coolant was flushed out.
