Just fitted powerflex and quick shifter FRS mk2
Old 25-04-2013, 08:18 PM
Matt Baxter
Back in black!
Matt Baxter's Avatar
Default Just fitted powerflex and quick shifter FRS mk2
Picked up a poweerflex torque mount bush kit and quick shifter for my Focus RS off Matt Lewis on sunday
I was a little bit dubious how much of a difference the poly bushes would make but Matt assured me that it was worth it so fitted them today (bit of dead time at work) and other than it being a bit of a bitch to fit lol I can confirm its a well worth mod for very little money
its removed the axle tramp on hard pull away and also appears to of helped the gear change a little so i'm very happy
then tonight I've fitted one of his quick shift kits as tbh thats what I was after from Mr Lewis on sunday and this is truly fucking awesome takes 5 mins to fit make the gears feel tighter still and more positive
So all in all well worth mods from a top bloke for little money
Old 25-04-2013, 08:25 PM
Mint FRST
Mint FRST's Avatar
Got a Elevate torque mount and 'Bryshifter' to fit to mine.
Also got a Mountune inlet and recirc to fit to. Expect the car to fell very different once all fitted!
Old 25-04-2013, 08:29 PM
st03ako
bullettoooo
st03ako's Avatar
Quick shift kit off auto specialist is too quality, torque mounts make hell of difference, slight but of vibration on tick over but cancels engine threw , any more mods planned?
Old 25-04-2013, 08:30 PM
Matt Baxter
Back in black!
Originally Posted by Mint FRST
Got a ElevatevTorque mount and 'Bryshifter' to fit to mine.
would like the mountune inlet for mine next got the recirc valve when Bryan did a group buy on them still not fitted not sure if it makes a difference either but know its needed when you up the power
Old 25-04-2013, 08:33 PM
st03ako
bullettoooo
st03ako's Avatar
I'll have an anembo one for sale in few weeks, got brand fire re circ valve on the shelf if interested,
Old 25-04-2013, 08:36 PM
Matt Baxter
Back in black!
I did look at the as one but Matts was cheaper and for me looked a little nicer
I would like a bit more power so will look out for an inlet as and when one comes up cheap
but tbh its an awesome set up for every day use
i did look at a full replacement mount but was warned away from doing so as they can be a bit harsh, after i fitted the powerflex kit i had a good go at moving the mount with a 24" pry bar and theres almost none so i'm happy
Old 25-04-2013, 08:39 PM
Matt Baxter
Back in black!
I would have been interested in the inlet if it was the Mountune one but Mountune wont add there map unless I was using there inlet
Old 25-04-2013, 09:01 PM
Matt Lewis
RS & ST Parts Specialists
Matt Lewis's Avatar
Glad you like it Matt, told you it would be a good little mod, regards to the inlet save the extra and go with the Anembo best mod i did on mine and get rid of all the symposer/resonator set up
Old 25-04-2013, 09:19 PM
st03ako
bullettoooo
st03ako's Avatar
Anembo one is good,looks part too,
Old 25-04-2013, 09:20 PM
RichieST
RichieST's Avatar
I fitted a torque mount to my ST recently, certainly does make a big difference!
Does the quick shift kit reduce the side to side motion of the gear lever, or just the foreward and back?
Old 26-04-2013, 07:04 AM
Cool Matt.
skypeller
19-09-2015 09:58 PM
matman
09-09-2015 05:45 PM
Churtz
15
13-08-2015 06:40 PM
Gadget
Ford Escort RS Cosworth
13-08-2015 06:43 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: Just fitted powerflex and quick shifter FRS mk2
