Help engine problems rs
Hello im new to the focus rs car is spluttering some times then ok its coming up these codes on my scan gauge its running direct boost forge actuator
p0234
p0002
p2000
Also just found out car has a software called tuna i would say its over fueling how do i stop it over fuelling
any ides would be great love the car and want it running 100%
thanks
p0234
p0002
p2000
thanks
focus rs 1672
p0234 is overboost code,normal for anything over 18psi.
could be anything from air leak on back of inlet to coil pack/leads/plugs or fuel pump.
id start with checking for air leaks as its free.
no probs mate thank. You wouldnt believe how many people who have problems with their car never post up the resolution to the fault that they had.
Glad you got it fixed mate just hope i can get mine fixed now
Stu @ M Developments
41
21-08-2015 06:47 AM
Zoggon
10-08-2015 10:39 AM
