Running Direct
Old 07-07-2012, 05:57 PM
adsrs1
adsrs1's Avatar
Smile Running Direct
Hi all just fitted a forge actuator with a blue spring and set the focus up to run direct got the boost set up to run at 22psi in fourth then drops down and holds between 20 and 21psi totally changed how the car runs holds boost right to the red line and allows you to put the power down better a lot better than how i was running through the amal valve and dreamscience race map where the boost comes in low down but drops of a lot more
Old 07-07-2012, 10:54 PM
Iain Roberts
Iain Roberts's Avatar
I'm running the same mate!! completly transforms the car and lads have been making well over 400bhp with running direct which is good!
DixieTheKid
11
06-06-2020 11:20 AM
dombanks
21-09-2015 08:38 PM
Eigdoog
13-09-2015 05:46 AM
Si B
12-09-2015 06:49 AM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: Running Direct
