my rs is pissing me off in the mornings when cold
i love the car to bits but whenever i use it for the 1st time that day it drives like a bag of dog turd.
i have a scangauge fitted and whenever it plays up it turns the scangauge off, and once back to normal it comes back on ??
it misfires through every gear and judders about as if its running on 2/3 cylinders. once warmed up and back to normal its fine
im running tubular manifold,
mongoose exhaust,
tuna remap
msd coilpack
k&n gen2 filter
running 22 psi
just for those who may wonder if it could be any of the mods.
also at around 10 psi theres a slight judder
any advice would be great
mongoose exhaust,
tuna remap
msd coilpack
k&n gen2 filter
running 22 psi
mine has started misfiring frm cold but only lasts 30 seconds or so. surley having under quater of a tank wouldnt cause this? mayb related to your issues
what base map are you on AF or AE as AE was always a pain for cold starts thats why AF was introduced but that can cause a cough at 4500rpm when tuning what are your plug gaps set at?and are they in good condition?
Different versions of the ford maps mate af is the revised map easy fix to this tho is let your car warm up before u spank it it's just over fueling cus of cold start
