3 button key fob
3 button key fob
hi folks just a quick question my 3 button key fob wont work even with a new battery if i was to buy a replacement off ebay have the serial numbers got to match?
found 1 but just the last letter is different
cheers
cheers
nice one marti did not know that ! so if when i use my st200 engine an keys with remote I can re-prog that to my car ?
Rite lets get this right if I buy a key off eBay I can programe it myself?? How?
And if I get a ket cutter to cut my key it will Work?? So this can be done for about £20 were as for charge over £150???
got new key off the bay with the same serial number followed all the steps to program it but no joy
anyone hav any suggestions
I used to use a Jaguar S / X Type key on my old Mk1 Focus 5dr. Just programmed it the way it tells you in the manual. The Jag key worked on my 5dr but not on my 3dr for some odd reason.
just took the key to have it tested and its not sending a signal ? is the red led surpose to light up on the key fob coz mine isnt so this could be the problem
I recently worked on a Galaxy (Two button), don't know if yours is the same but be very careful, I tested the battery and it was fine, thinking it can only be the battery I got a replacement, fitted it only to find it still did not work, I found this very strange, I eventually figured out that there is in fact TWO batteries, when I removed the first there was a metal plate beneath which I thought to be the contact plate but once removed there is another one beneath, once this one was replaced all was well!
Yes red LED is supposed to illuminate when button is pressed!
Martin
Martin
TC-ST3
26-09-2015 04:47 PM
NC53
13-09-2015 03:05 PM
