Removing bumper from focus RS mk1
Im going to be doing it to give it a clean up etc, just wondering how i should go about doing it and what i have to remove before i just go ahead and end up wrecking it haha
thanks
thanks
Put car on ramps or jack up.
Unclip indicator and fog light connectors.
Remove front grill from car.
Remove 3x plastic clips from the front of each arch liner and 2 from up each
arch edge.
Put arm inside arch liner and undo 10mm bolt from bottom of headlight.
Remove 2x bolts from top of headlight, un clip loom connector and remove headlights.
Remove 4x plastic clips from rear of the undertray.
Remove 3x nuts from inside edge of bumper/wing and remove plate also (both sides)
Press down on retaining lugs on the top of the bumper and pull forward, the bumper
should now come off
arch edge.
should now come off
09-10-2015 07:38 PM
track.focus'd
12-08-2015 05:53 PM
