Tuning a Mk 1 focus RS
Hi
Can anybody advise where is a good place to get a mark 1 FRS tuned to around 350bhp and what would be required to get it to this power?
Any help is much appriciated
Tony
Tony
focus rs 1672
join the rsoc and the new frsec site,you'd be better buying the bits and adding them yourself or contact demonpete from stanthorne cars http://www.stanthornecars.co.uk/ and he'll help you no bother.
turbo - guy on the above sites called johnfrs,he builds hybrids for these cars and there top notch
manifold - theres pd and jek,these are prob the best,then theres miltek and blueflame the best of the rest
actuator and dv007 recirc dumpvalve- get these from forge motorsport with a blue spring or if you want to run a boost controller yellow spring and yellow spring in the dump valve if your running blue spring in the act
exhaust- mongoose,miltek,blueflame or if your really flush a pd one
gen 2 - contact graham at car parts express http://www.carpartsexpress.co.uk/ he should be able to get you one of these
decat - again same as exhaust mongoose,miltek etc
air to air intercooler(optional,not needed unless car gets a doing) pro alloy,radtec,airtec,all pretty much the same
these mods should give you 350bhp,clutch may last it may not,options for them is ap paddle,ap organic or sachs racing clutch,carpartsexpress for these again
and youll need some decent brakes to stop.ap 6 pots or contact shins from above sites and he can get the ap 2 peice which alot of frs guys use
hope that helps
hope that helps
can run on standard map, my mate ben had a johnfrs turbo and blue flame exhaust with decat with manifold and just reset the ecu after fitting, had the afr checked and all was good
heres the car on the rollers, not sure if this was before of after the manifold was fitted but pretty sure he ended up with 360bhp
http://www.youtube.com/watch?v=MiZXG..._order&list=UL
focus rs 1672
i promise you the map hadnt been touched.
ill try and get him to post on here. he was still on the generic map.
car was totaly standard when he bought it.
ive asked him too post up on here when he gets time so hopefully he will and give the full spec of the car.
he no longer owns it though.
he was a regular on the rsoc site.
Think what the lad is saying is the map didnt need to be customised (re-mapped) but the bluefin or which ever generic map worked fine with new mods after a ecu reset.
focus rs 1672
having no map with a decat would throw up the eml and very much doubt it would make 360bhp on std map
SMILER258
28-09-2015 09:04 AM
