Ford Focus Ghia X?
Nope just a Ghia.
Pre Facelift had two different specs depending on the engine.
2.0's and SOME 1.8's had Rear leccy windows and a trip computer. Along with TC.
Most 1.8's, 1.6's and 1.8TDDi's were basically Zetecs with wooden trims
Post facelift all Ghias have Climate Control, rear leccy windows and a trip computer.
I have a ghia 1.8 tddi estate 2000 model
Full leather and rear leccy windows over the usual climate pack etc etc
No trip computer or cruise control though
Well my Ghia X has got an electric sunroof, cruise control and bi-xenon headlights. These items together are very rare on a Focus mk1. It has every option you can think of except no heated seats. And that option you find even in the lesser basic models..
I know with the Pug's that use a Mechanical pump you can't fit a trip computer as it has no way or working out how much fuels been through it etc
Getting a TDDi Focus is looking more appealing every day. Shame about the crappy Lucas pumps though
They are not the old Lucas CAV rotodiesel pumps as used on the previous generation of Mondeos and Escorts. Saying that, I never ever had a problem when I had cars with that pump back in the day.
The Focus TDDI uses a Bosch VP pump which is fully electronically controlled. The said same pump that VAG used to use on their TDI's.
The fuel computer was plug and play on mine, all I needed to add was the stalk (indicator stalk with the button on the end to cycle through the fuel comp's functions) and an external temp sensor. I never bothered with the washer bottle sensor.
The only thing that is a bit squiffy on the TDDI is the range function. This is due to the TDDI having a 53 litre tank opposed to a 55 litre tank the petrols have. The MPG offset can be calibrated from the fuel comp and is very accurate once set up.
Hmmm.
I've read this a few times.
I cannot conlude what on earth your on about
All I can conclude is that it was posted at 9.32pm and that you were probably very very drunk at the time.
And I tell you what, if your arsehole can reply to forum threads, get down to the circus. You'll make a fortune.
There are always oportunities for arseholes with talent
Did yours come with the x4 leccy windows ?
Mine has got only the fronts and upgrading to rears means a swapping out the front loom and adding a rear loom.
I'm interested if you did this and how you got on?
Also got heated leathers as well on mine which are very nice indeed.
More seriously though and don't offense from my japey reply above;
Nahh mines is 4 leccy windows from the factory fella
