ford focus st3 (wont start)
Hi all im hoping some one might be able to help me i ahve a for docus st3 this morning i went round to a pals then when i went to drive the car again the engine is just not kicking in it is just making a clicking noise any help as to wat the problem may be would be very much appreciated thanks daz
st170 breaking
the car opens with the key and everything works ie stereo lights etc. i have the electronic start button when it tells me to push the clutch to start so i do thats then when it clicks but is not starting the engine!!!! does this sound like the prob u had???? manythank daz
As said it's a flat battery either it's not charging or the battery needs replacing, the CD player will tell you nothing but if you switch the headlights on and then tried starting they should go dim confirming the problem, you could always bump/jump start as a temporary measure to get you on your way.
Martin
Martin
