MK1 Focus RS Knocking From Bottom End, or Gearbox????
Hey People
Need some help with my FRS, Ive got a slight knocking noise from the bottom end or the gearbox, i cant quite make out were its coming from. Ive also found oil on the exterior of the gearbox casing, WORRIED!!!
Any help would be appriciated.
zetec engines are prone to weep oil from the rear crank shaft oil seal behind the fly, this runs out the bottom of the box. it should not cause a knocking sounds though but could eventually contaminate the clutch friction plate. does the sound go away if you depress the clutch?
track.focus'd
12-08-2015 05:53 PM
