PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Focus > Ford Focus RS
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 07-05-2010, 09:47 PM   #1
Pikey735
Trader Score: (0)
Pikey735 is on a distinguished road
Default St 170 tuning........
Hey guys, I've got an st170 and am considering chucking a bit of money at the motor, I realise that being 160bhp ish out of the box, real gains won't come cheap, I've read about adjusting verniers on stock cams, using different intake ducts etc..... But was wondering if the standard management could be re-calibrated to work with a lairier set of cams, catcams list a few sets, but with the vvt, what options do I have? Has anyone done much research into tuning these without going FI???
Pikey735 is offline   Reply With Quote
Old 08-05-2010, 10:40 AM   #2
Sp3no
Sp3no's Avatar
Trader Score: (1)
Sp3no is on a distinguished road
Put it this way i have spent nearly 2grand on my ST170's engine and all i have to show for it is 189bhp, there is not allot of tuning potential here as a N/A engine, even with TB's you will only see 220ish, the weak point is the oil pump, they do not like to be revved past 8000rpm so unless you plan to switch to a dry sump set up i would go for forced induction or buy a faster car. Lairy cams generally mean higher revs, even billet oil pump ring gears have been known to fail at high revs. The standard black oak managment is not an easy unit to tune, the best thing you can do is get a generic map unloaded from the likes of Dreamscience.
You can only fit a verier cam to the exhaust pulley due to the VVT on the inlet side, i have a CFM one fitted to mine retarded 6degrees, it gained roughly 5bhp for this mod, torque of the devil will supply fit and set up the pulley for £350
Sp3no is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
