| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Focus RS This forum is for discussion of all things pertaining to the Ford Focus RS Range. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
I have a similar problem...The fuse in the engine box had blown... and the resistor pack behind the gove box had burnt out..both have been changed for new... But i still have no fan heater...
My T reg Focus is the one without the Aircon..but from other threads i'd seen..thats where i started.. |
#3 |
The common problem lies with failure of the resistor pack burning out, when this happens you have no blower except on position 4, as you have nothing this is not your problem, of course it could have gone all together.
Obviously first check the fuse which can be found in the engine fuse box, if this is ok then check the terminals for +12V (Only one will have power) with the ignition switched on. If you do then the problem most likely will be the motor or something in between, so I would check if the motor itself works by putting power directly to it. The A/C light works so by that I would think the switch itself is ok, otherwise the A/C light would not illuminate. Martin |
| Display Modes | |
