| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Focus RS This forum is for discussion of all things pertaining to the Ford Focus RS Range. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
Could well be related, when you push the switch you should hear a click from behind the dash, if this happens it shows the relay to be working, so will be problem with the wiring or the screen itself but it should clear a little so is a power issue, the price seems excessive to me I would have a look but your a bit far from me.
Martin |
#3 |
I'm afraid I had been getting my Front and Rear Heater Buttons mixed up.
I thought the button with the Pie Shaped Screen was the Rear and the Square Screen the front however whilst changing the Rear Heated Screen Relay (No 25 in the Central Fuse Box) it appears that it was working all the time (the relay that is) When I press the Square Screen Button (Rear Heated Screen) the relay clicks and the light comes on (The engine has to be running) but the rear screen does not heat up. When I press the Pie shaped button (Front Heated Screen) there is no click the light on the switch comes on and the internal lights visibly dim. They do not dim when the Rear Screen Heater is switched on. I have changed the Relay and the Fuse but the Rear Heated Screen is still not working any idea how to test from here, I have a multimeter and I'm not afraid to use it !!!! Ta |
#4 |
check for 12volts at rear screen conters if 12volts there wiring ok will need new glass
__________________
martyn j |
#5 |
#6 |
I know on the new shape focus the connections on the front screen are under the plastic scuttle panel (the plastic panel that the wipers come out of), basically water gets in there and the connectors can go rusty. Maybe thats something to look at?
__________________
#7 |
Ok I found the rear heated screen connector there is a small plastic cover to right of the side covering above the parcel shelf as you look when sitting on the back seat facing rearwards. Its a pain to get to so I ended up removing most of the plastic trim.
I disconnected the feed wire yellow/green (I think) and with the rear heated screen switched on and a multimeter set to 20v one probe connected to the feed wire the other earthed on the rear door connector bolted to the rear wheel arch I got no reading. I have followed the cabling to just under the front dash and can see no visible damage. The relay clicks and the fuse is fine, there is 12v being fed to the fuse but I have not checked the voltage to the relay. Looks like the screen is OK but its not getting power , I suppose I need a wiring diagram or take it to the garage?? |
#8 |
You sure it was the live you found and not the earth? I think they should be on opposite sides of the glass, you might have found the earth connector, try the other side.
__________________
#9 |
#10 |
Easy way to check if its earth or not is check if you have continuity between the plug you have found and the door latch, with ignition off!
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Focus St170 Heater controls | aRSe_Kicker | Ford Focus RS | 1 | 11-07-2009 10:11 PM |
| Focus Saloon!!! | Slik Johnson | General Car Related Discussion. | 3 | 27-06-2009 12:57 AM |
| Ford Focus Saloon ST - Why Was It Never Produced? | Benni | General Car Related Discussion. | 10 | 09-07-2007 12:56 PM |
| FOCUS F2 SALOON, | 666 de' vil | General Car Related Discussion. | 2 | 04-02-2007 12:15 AM |
| focus saloon.. | cossie690 | Pictures, video & Photoshop Forum | 3 | 28-07-2006 07:30 AM |
