| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Focus RS This forum is for discussion of all things pertaining to the Ford Focus RS Range. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
Fleet Manager
get it into an a mechanuic mate diagnosit machine will find your faults
__________________
![]() Click to see my RS Turbo project http://passionford.com/forum/showthr..._g#post3406438 |
#3 |
![]() BANNED |
Clean the MAF first with carb cleaner, give it a good dosing, then shake dry, then reset the KAM fuse in the fusebox, it is a 2 amp violet colour fuse, this will make the ecu relearn it's best setting, so will be a little lumpy to start with but after around 5 miles of mixed driving should be fine.
Another thing to check is the dreaded "T" piece of rubber, this is near the rear nearside corner of the head underneath all the gubbins, and connects the PCV valve at the front into the inlet manifold, these split and leak air, the pcv valve can also jam, just squeeze the hose shut with pliers to test. tabetha |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| white smoke and poor idle. PLEASE HELP! | mikey_clough | Ford Escort RS Turbo | 12 | 21-10-2008 08:27 PM |
| poor idle and stalling | cossiejim | Ford Escort RS Turbo | 3 | 06-09-2008 09:07 PM |
| Would a MAP sensor cause poor idle? | Paulo P | General Car Related Discussion. | 8 | 31-05-2008 11:17 PM |
| focus st170 high idle & poor throttle response when cold | mrmcmint | Technical help Q & A | 0 | 27-04-2008 12:50 PM |
| poor idle on zetec | jdfiesta | Technical help Q & A | 5 | 15-05-2007 02:08 PM |
