PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Focus > Ford Focus RS
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-10-2009, 09:34 AM   #1
clonsingle
Trader Score: (0)
clonsingle is on a distinguished road
Default 2000 Focus overheating while driving but ok when Idle or stuck in traffic
My 2000 focus is overheating when driving fast (40+mph). Its OK when driving slow or idle. I have replaced the following:
1. Radiator
2. Thermostat
3. cylinder head temp sensor
4. timing belt
5. Water pump
The mechanic is 100% certain its not a head gasget issue (he said "you would see coolant in the oil, compression would be effected, oil in the coolant, coolant would be bubbling in the reservoir etc etc ")
There is no sign of a coolant leak anywhere.
When I run Self Diagnostics Mode no DTC codes appear. I even reset the computer!
I checked the two hoses in/out of the radiator and they are at the same temp (after the engine is left idle for a while)
Anyone have any ideas on what it might be?
clonsingle is offline   Reply With Quote
Old 21-10-2009, 10:09 AM   #2
adam151082
adam151082's Avatar
Trader Score: (0)
adam151082 is on a distinguished road
thats a bloody strange one. take it your water levels ok? could it be you radiator is covered up some how so when the engine is under load and producing more heat its not gettin enough air flow to cool it?
__________________
Don't worry; it only seems kinky the first time.
adam151082 is offline   Reply With Quote
Old 21-10-2009, 10:23 AM   #3
clonsingle
Trader Score: (0)
Quote:
the water level is fine. There is no blockage in front of the rad. I can drive it at low speed but high RPM and it stayes at the correct temp. It only seems to happen at a high speed - not effected by the engine RPM
It is strange indeed, wonder if the guage is faulty (the self test seems ok though)
Old 21-10-2009, 10:30 AM   #4
adam151082
adam151082's Avatar
Trader Score: (0)
if its not affected by the rpm then i'd say it must be a faulty gauge or sensor.
__________________
Old 21-10-2009, 10:39 PM   #5
MATT222
Trader Score: (0)
MATT222 is an unknown quantity at this point
have you bleed the coolant system? could be and air lock?
have you used the cluster to tell you want the engine temp is?? (this way you know if it is over heating)
hope that helps Matt
MATT222 is offline   Reply With Quote
Old 21-10-2009, 10:47 PM   #6
coco16i
coco16i's Avatar
Trader Score: (0)
coco16i is an unknown quantity at this point
If you hadn't mentioned that you have already replaced the water pump i would have put money on it being the problem !
Seen quite a few give bother, the plastic impeller breaks away from the pump body and wont pump the water through the engine at higher revs or when out driving on the road, usually alright when at idle and only heats up when driving.
Other than that this sounds like a real strage one, faulty temp sender maybe ?
coco16i is offline   Reply With Quote
Old 24-10-2009, 10:00 AM   #7
Trader Score: (0)
tabetha will become famous soon enough
Sorry if I missed something here, but WHY do you think it is overheating ?, ie what is it doing to lead you to this conclusion ?.
Don't under any cicumstances assume the gauge is anything like remotely accurate, could just be a dicky cts(gauge one) if it's the only reason you believe the engine is overheating.
tabetha is offline   Reply With Quote
Old 03-11-2009, 08:45 PM   #8
martysmartie
Trader Score: (1)
martysmartie will become famous soon enoughmartysmartie will become famous soon enough
+1, to add are the cooling fans activating? If it's genuine overheating they should do
Martin
martysmartie is offline   Reply With Quote
Old 11-12-2010, 10:36 PM   #9
SnackaJacques
SnackaJacques's Avatar
Trader Score: (0)
SnackaJacques is on a distinguished road
Did you find a solution - mine is doing this.
J
SnackaJacques is offline   Reply With Quote
Old 12-12-2010, 01:22 AM   #10
martin 09
Trader Score: (0)
martin 09 is on a distinguished road
start it up look under bonnet and look for any coolant coming out from any where whilest giving a few revs of the throttle bodie might be throwin water out under load ive had this happen to one of my cars and it turned out to be this a very tiny hole in a ipe that was throwin water out at pressure when the engines revs are running higher therefore the water pumps throwing the water round at more of a rate causing the pressure to allow it to leak and obviously during idea not doing so allowing the coolant to flow correctly etc. worth a try
martin 09 is offline   Reply With Quote
Old 13-12-2010, 11:12 PM   #11
LewisT
Trader Score: (0)
LewisT is on a distinguished road
check the small hose one the top of the termostat make sure its not blocked just a guess pretty sure it lets the air bleed from the system
LewisT is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
2000 w BMW 530d lumpy idle. Any ideas? Kirbycossie General Car Related Discussion. 12 28-07-2009 07:16 PM
overheating/idle control triplej Ford Escort RS Turbo 2 14-03-2009 09:33 AM
focus rs fan stuck on S1 Lee Technical help Q & A 3 03-08-2008 06:56 AM
Would the wheels of a Focus MP3 fit a 2000 focus estate? Aaron1204 General Car Related Discussion. 9 07-10-2007 06:49 PM
overheating in traffic??? Rturner Ford Escort RS Cosworth 6 17-02-2007 04:32 PM
