post your focus
#203
jemesxp, I think you'rs is the same as mine, Aquamarine frost 1 066 836, can't be sure because of the light in the photos.
It ain't worth me posting pics of mine, as it's pretty much the same as James', but with a load of bumps and scrapes, bare standard steelies, and tinted windows, almost as I bought it. Have put an induction kit on, and should be getting an st170 manifold for it this weekend. I'm liking the idea of keeping it looking beaten up and standard, just putting my money and attention into the mechanics.
#208
#209
here's another pic, I'd say the color is the same, this has better lighting I think..
and don't worry, this car is hiding a few bumps too
#213
Love your white focus riks2rst. Compos are the balls...
If you drop it and smoke the front blinkers would be perfect for me. Well done...
One more of mine
on summer wheels set...
One more of mine
#215
19-06-10_2059.jpg?t=1277162821
20-06-10_0015.jpg?t=1278254477
26-06-10_2027.jpg?t=1278254124
03-07-10_0302.jpg?t=1278254171
15-08-08_2239.jpg?t=1277163339
few pics of my mates 4x4 focus on the road soon. and a pic of my white rs when i was building it
#230
560whp US spec Zetec
2003 CD Silver zx3 purchased brand new 12-27-03 only options were AC (which is still intact and working!) cruise and alloy wheels. Completely stock exterior.
Supertech 8.7:1 pistons 85.5mm bore
eagle rods
ford bearings
zetec block bored to 85.5 mm decked .010"
Cometic head gasket .047" thick
ARP main and head studs
Custom ported head by me decked .015"
Supertech back cut valves
Eibach valve springs
Comp stage 2 cams
AEM cam gears intake straight up exhaust -4 deg
Jay Racing intake manifold
all 3 VF engine mounts
Top Speed Street turbo kit gt3582r w/ TiAL SS .63ar turbine housing
TiAL MVS 38mm wastegate dumped like a man!
TiAL Q 50mm BOV
3" turbo back exhaust full v-band, Magnaflow muffler vibrant Super Quiet resonator
return style fuel system with twin walboro 255lbh pumps in the stock tank -6 feed line stock feed as the return
modified stock fuel rail
Siemens 83lb injectors
Aeromotive FPR 1:1 rise 50lb base fuel pressure
stock MTX-75 with 3.82 gear
Competition Clutch stage 5
Fidanza aluminum flywheel
torsen atb diff
Eibach Pro System dampers
Intrax sport springs
Eibach 22mm front sway bar 24mm rear
Lakewood traction bars
Hawk HP plus brake pads (I think)
black 17x8 38et Wheels
245/40/17 Hankook Ventus evo v12
AEM wide band
AEM Tru Boost boost controller/gauge
Top Seed Performance SCT custom tune
Bride Low Max ridged w/ custom aluminum brackets
Sparco 3" 6 point harnesses
Top speed custom .083" CM roll bar
This set up makes about 400whp on 19psi and 93octane (which is my wastegate spring) and 530whp on 27psi and 111 octane race fuel.
eagle rods
ford bearings
Comp stage 2 cams
TiAL Q 50mm BOV
torsen atb diff
AEM wide band
#232
26-06-10_2027.jpg?t=1278254729
03-07-10_0259.jpg?t=1278254797
03-07-10_0302.jpg?t=1278254866
will get full spec up soon
#233
burning oil
Heres my focus tdci sport. Only had it a few weeks but already fitted a green panel filter and roverron tuning box. Goes really well now
Going to lower it a tad and get my spoiler fitted when ive found somebody to paint it on the cheap
#234
ffoc.co.uk
That's one tidy car, looks like just out of the showroom .
