Charge cooler water pump???
Old 07-01-2008, 08:54 PM
AJB
AJB's Avatar
Default Charge cooler water pump???
This might seam a bit of a strange question, my mates just got a Focus RS and the charge temps are a bit high. I was wondering if the charge cooler has an electic pump on it and does the speed very, or is the pump driven off the engine. Also where is the pump located just to save me a bit of time. He is considering fitting a front mounted intercooler if the charge cooler is at its limit, do you normally have to remove the pump to fit these?
Old 07-01-2008, 09:13 PM
PAUL JA
PAUL JA's Avatar
What temp are you seeing?
The pump is electric, mounted nearside front, you can see it through the front bumper vent. To prove its working if you take the top off the chargecooler header tank you should see a fine jet. Check the level only when cold / engine not running.
From Ford - £600 approx, look at the RSOC forum someone on there can get them for about £130.00
It you go front mounted intercooler the chargecooler / pump etc comes off
Paul
Old 08-01-2008, 12:38 AM
testastretta999
testastretta999's Avatar
Default Cahargecooler
No need for front mount intercooler until 350 bhp.
Pump is situated under nsf, you may find it is the connections that is corroded and only needs cleaning.
I think it is minimadgriff that gets the pumps at sensible money.
Old 09-01-2008, 05:58 PM
AlexRS2782
AlexRS2782's Avatar
Default Re: Cahargecooler
Also known as Captain Panic the Purple Freak rofl
markeh
Ford Focus Diesel
11-04-2016 02:15 PM
155lee
27-10-2015 04:55 AM
Dave_b
Ford Focus (All Models)
13-10-2015 05:48 PM
timsrs
22
24-09-2015 08:14 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: Charge cooler water pump???
